The unit appears to record ok but on playback the picture freezes sometimes. it may start again either with encouragement or on its own if it does start none of the program is lost, hence I say it is recording ok but playback is unreliable
  • 604 Answers
I wish I knew what you were recording to, is it a hard drive? if so, it sounds like you need either defragment the drive (not easy unless its in a computer)., or lower the resolution of your recording device, e.g. change from HD to SD, hope this helps
Posted on Mar 10, 2011
500gb playback
Have you tried resetting it? Use master reset to bring factory default settings.
Car Performance Chip
Aug 17, 2012 | Sony Televison & Video
Dish 622 freezes up
You have a hard drive failure and will need the unit replaced. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
Nov 25, 2008 | Humax DRT400 TiVo 40-Hours Video Recorder
ILO Recorder DVD05R - Playback jumps 10min, 20 min and more...
Does the disc still play in other dvd player? My ILO has always been picky to play rentals so I just have a cheap COBY player hooked up to front inputs of my ILO. I use it to watch the dvds, only use the Ilo to record. Saves wear and tear on my ILO but cannot find a universal remote to operate them both and my tv. If it still records okay thats what I would do, just watch the discs in a secondary unit. Sounds like time to start shopping for new recorder.
May 04, 2008 | iLO DVDR05 DVD Recorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Suspected faulty hard drive Topfield TF4400PVRt
any hard drive that has the same plug connections will work
consider a solid state hard drive as there is no moving parts to wear out
formatting actually cleans the slate for the hard drive so with a new hard drive ir would not be necessary unless the top field system uses any other that NTFS format
Oct 21, 2017 | Televison & Video
Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
Jan 11, 2008 | Philips DSR708 DirecTV DTV Receiver /...
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture freeze
have you tried to plat back on another player.?Could be either at fault,seeing as is playing back ok on cam would suspect your player.try playing on another player to see which at fault.
May 13, 2007 | Panasonic VDR-D250 DVD Camcorder
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
