How many faces are on a triangular prizm - Computers & Internet
  • 1,133 Answers
Four, the three sides of the triangle, plus the base.
Posted on Mar 10, 2011
How do i do volume and surface area of triangular prism on ixl
Hello Jacqueline;
My name Peter. I am a engineering college graduate. Later I changed careers and now, I am a retired field service appliance technician. So, I work on the side and it you have any appliances that need repair call me @ 414306-1362.
The length on one side of the end triangle is "a"
The area of the end triangle is: (a x a) x 0.433 = Surface Area
The surface area of the prism face = a x length.
The volume is: The surface area of the end x the surface area of the face.
Mar 06, 2015 | ixl.com
I need help with burda 7187
Usually with a wrap dress, you join front triangular pieces to bodice back at shoulders and side seams (often leaving a slit open in one side seam to pull the tie through). Then stay stitch neck and front edges to prevent stretching. Then neaten neck edges turn and stitch, or attach a facing. Probably if this pattern has a facing then you may need to attach skirt to waist and also attach the tie ends to the front edge before facing is attached. So when you turn facing to inside you will have the tie end in position at the point of the bodice/skirt seam on both sides of the dress.
Feb 28, 2015 | Sewing Machines
Car radio removal
remove dash face plate around radio there will be small screws or studs with nuts around the sides of radio attached to a mounting plate. Unhook wire harness on radio and pull from dash
Mar 02, 2010 | 1995 Geo Prizm
What is the sum of the function f(n)=(nth triangular number)^2 when n= 1,2, and 3
The function is: f(n) = (n-th triangular number) ^ 2
So, f(1) = (first triangular number) ^ 2
the '^ 2' means "multiply the number by itself", e.g., '3^2' is '9'.
And, f(2) = (second triangular number) ^ 2
and, f(3) = (third triangular number) ^ 2
So, what is a "triangular number" ?
Do an Internet search for "definition triangular number",
and you may find the web-page;
http://www.mathsisfun.com/definitions/triangular-number.html
which gives a definition, plus pictures to help you visualize why they are called "triangular". Hint: a "tri-angle" has 3 sides, while a "quad-rangle" has 4 sides.
Sep 24, 2009 | M2K Garfield: It's All About Math Math...
Key igntion switch is stuck
I would suggest wiggling the shifter up past park. It may loosen it up. Also you can lightly tap around ignition to get the pins inside to release.
May 22, 2009 | 1997 Geo Prizm
I took my shelves out to clean my oven and cant get them back in
Hello, as you are looking at the rack the two triangular shapes face down the scooped part at the rear facing up. pick up the rack put your hands on the little triangles facing down put the scooped end in on a downward angle about (30 degrees) slide end in first and straighten out. good luck
Dec 22, 2008 | Kenmore 42161 / 42169 Electric Single Oven
I need help
Hicksashley,
When you look at the engine on the pulley end you must find a triangular pointer on the main pulley and then look at the two or four cam pulleys for a dot like dent on the fin of the pulley. These are marks for timing, firstly you set the main pulley with the timing mark on the pulley to the triangular mark on the engine just above the pulley to the right or to the left, then you put both cam mark facing each other on the insides level with the top of the block. that it you should be able to start her up if your plug timing is in order,
Aug 13, 2008 | 1998 Mazda 626
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Computers & Internet Logo
David Payne
David Payne
