Question about Dryers
Dryer heats up some but not drying clothes - Dryers
    Master:
  • 414 Answers
If it is an electric dryer then your duct work may be clogged. This would require
multiple cycles of the dryer to finish one load. Also the internal ductwork of the
dryer may be clogged. It will cause the dryer to shut off the elements with the
resettable limit. If it becomes too clogged, the safety limit (one time limit) will
open and the dryer will not heat at all. Lowes sells a nice auger kit for dryer vents
(about 36 dollars) or you could have the unit and ductwork serviced by a handyperson
if you are comfortable taking this apart and cleaning it, just be sure the power is off
and the unit unplugged. Hope this was helpful..
Posted on Mar 10, 2011
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
