Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Where to find replacement Diamond Shield at reasonable price
My granddaughter decided to draw on our screen with a paper clip and now the diamond shield has scratches all over it. Where can I find one so I can replace it myself. The coating on the Diamond shield is coming off and I need to replace it. Mitsubishi does not make or carry the part any more. Does anyone know where to get one?
  • 14 more comments
  • bldrno1 Aug 01, 2008
    They do not carry it.
    i would rather pay for a replacement. since it is an optical product, a filler would not be very practical.
    none of those solutions work.
    All the same answers that didn't work the first time.
  • bldrno1 Aug 04, 2008
    Discontinued
  • bldrno1 Aug 05, 2008
    don't need one
    Neither place carries it.
    there is an antiglare on the Diamond Screen. if i replace it with plexi glass there will be a glare. I have to many windows.
  • bldrno1 Aug 06, 2008
    That is just a clip, not the Diamond Shield.
    They said there shield is damaged also.
    I have called Mitshubisi and they gave me 5 different repairs shops, none of them could help me. the part can not be found.
    too much work. I was hoping someone knew where to order one.
  • bldrno1 Aug 07, 2008
    still no luck.
    President:
  • 778 Answers
You can find anti scratch, anti glare, and anti reflective coatings here: http://www.tspinc.com/anti-glare.html
Then apply them to a thin lexan, plexi, or mylar shield to solve this issue.
Posted on Aug 07, 2008
    Genius:
  • 1,226 Answers
No luck of what you needed, so just keep on posting maybe someone can help you. I tell you the truth, your problems is unique and this parts of the TV rare got in troubles. However, just keep on hoping.
melnavz
Posted on Aug 06, 2008
  • 876 Answers
Just a thought- call a windshield repair business and check with them. I know they do some diamond shield repair . I know you mentioned that you prefer a replacement. They may beable to do that as well. I'd give a few a call. Good luck to you!
  • Gayle Ashbach
    Gayle Ashbach Aug 06, 2008
    Altenately, you could search the thrift stores for the same monitor and use it for replacement parts. I don't know what is available to you, but in our area, we have Good Will Industries wihich carries an enormous amount of electronics. We also have a free classifieds publication in our area which is very popular, just for this type of thing. You might check to see if there is something similar close to you.
  • 813 Answers
U have to with a professnol tv repairer
    Genius:
  • 2,035 Answers
Please you use this link to check a second hand TV from ebay and you can use this screen for your TV:
http://cgi.ebay.com/Mitsubishi-WS-65813-65-in.-HDTV-Television-Diamond-_W0QQitemZ140255092488QQcmdZViewItem?IMSfp=TL0808041131r17273
Good luck...
    Genius:
  • 1,447 Answers
Hi-
Try this first
how to fix your scratched LCD monitor after a scarring encounter with a sharp object.Two different methods for addressing the LCD scratches, from a temporary fix involving a little petroleum jelly to a more difficult but permanent solution that involves removing the scratch and re-lacquering your monitor.
if all fails, call manufacturer and ask for their parts distributor instead for you to get the exact model type of the LCD you want.
Thanks for using Fixya!
  • 319 Answers
Sir
I have found an outlet that advertises a diamond shield screen for 65 inch mitsubishi tv's.
Please click here for replacing your screen!
Kind Regards,
Brian
Posted on Aug 05, 2008
    Genius:
  • 2,028 Answers
If what I'm reading about the diamond shield is correct, this is nothing more than a Lexan screen protector. Since Mitsubishi has discontinued the model you have and it seemingly can't be found, I suggest that you make your own. Lexan is merely a high quality Plexiglas that is more durable, scratch resistant, and has a better visual quality. It's commonly used for motorcycle windshields. You can purchase Lexan at various hardware stores in the required thickness, and cut to the dimension you need. This should work fine, and will be less costly and time consuming than finding the diamond shield.
    Genius:
  • 1,665 Answers
Here is a downloadable version of your service manual
Posted on Aug 04, 2008
  • 2,296 Answers
Call the sears parts department, they seem to have the part you need. Click here.
Posted on Aug 01, 2008
  • Mitsubishi Master
  • 19,396 Answers
Order parts from Mitsubishi here : Parts Search
  • 640 Answers
Bldrno1,i have done some research for you and its very hard to come up with one,ive googled and yahooed replacement screens and have found tht some kits cost 500 bucks.I would try a filler for plastics or cars for scratches and see if this helps as the screen is already damaged.Another idea is to find a broken t.v. from someone and buy it cheap and swap screens.
    Genius:
  • 1,142 Answers
You can get the diamond sheild from here
http://www.vancebaldwin.com/
  • Maanita Chadha
    Maanita Chadha Aug 01, 2008
    Vance Baldwin maintains a call center with
    highly trained parts consultants to take your call and help you get the
    parts you need. Give us a call at (800) 432-8542.
    Corporate Headquarters
    7060 State Road 84 #12
    Fort Lauderdale, FL 33317
    P (954) 723-9191 (800) 432-8542
    F (954) 723-9044 (800) 552-1431
    Distribution Facility
    1655 Lakes Parkway NW
    Lawrenceville, GA 30043-5858
    F (678) 377-7599
  • 6,487 Answers
Check this link I believe they can help you with this http://fixmymonitor.com/
Hope that helps..........
2 Suggested Answers
  • 395 Answers
SOURCE: Where to find replacement Diamond Shield at reasonable price
part # 760D627060 you can get it at www.vancebaldwin.com for $136.30 plus S/H
Posted on Feb 18, 2008
Need a replacement diamond shield PLEASE!
Tries this websites Tv Repair World.com,Shopjimmy.com or Partstore.com.
Sep 18, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Diamond Shield for Mitsubishi VS45605
Unless you have small children it's better to just remove the diamond shield and throw it away. Less glare on the screen that way. But if you must have a new one go to a local glass shop and have a piece of plexiglass cut to the dimensions of the old one. We do that all the time and it works fine. Usually runs around $60.00.
May 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Diamond shield
It seems these TV's are going bad right and left. I would look on Craig’s list for a cheap/free 55" Diamond TV. Not sure what you would do with the left over TV. I just picked up a 55" Diamond for free and hope to fix it. If I don’t get it to work, you can have the screen (California).
Aug 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi diamond shield
Yes the site I work for just parted one out today they just listed it on the website today. It comes complete with lenticular screen and diamond shield. Its excellent condition It sell for 125.00 and that includes shipping and handling. heres the link.
http://servicemanuals.vstore.ca/ Its listed under mitsubishi parts.
Mar 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
My Mitsubishi Diamond Sheild also had scratches on it, and I solved the problem at no cost by taking some automotive wax, and hand-polishing the shield with a smooth rag (old t-shirt works great!) Leave it right on the television, no need to take it off.
HINT: Don't leave wax on too long, and just do a small section at a time.
Feb 18, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Screen replacement
Post a email link and I will email you the page from the service manualshowing the disassembly proceedure.
Jan 27, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Behind plastic screen looks to have dust on it
That front screen is what Mitsubshi calls the Diamond shield. Every set is differant but easy to do. Look carefully at the top and the bottom or the lrft and the right, fr clips that run the entire lenth of the top and the bottom or the entire lenth or the right or the left side. They bsimply snap into place. Mitsubishi says to gently insert a small screwdriverbetween the diamond shield and one end of each on of the two clips and gently pull off the clip. Good Luck
Mar 20, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
563 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
