Question about HP PSC 1315 All-In-One InkJet Printer
Trouble shooting my printer all in one 1315 series
My printer HP 1315 series , when i put it on, printer start taking the paper sometimes more than one paper per role , without printing any thing although there is an order to print some file and new ink cartriages and paper were installed and alined, the printer all last showing the red lamp indicating to check paper or print cartridge ...
  • 181 Answers
You need to clean the rollers in the back panel of the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and plug printer back in. It should come on by itself and initialize.
Print a page from your computer. It should now only feed a single sheet at a time.
Posted on Aug 07, 2008
My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
Sep 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
Trouble shoot keeps saying paper jam and there is no paper jam
Try removing and reinserting the access door at the back of the printer. It works most of the time.
Feb 07, 2011 | HP PSC 1315 All-In-One InkJet Printer
The printer won't pick up the paper. there is plenty of paper in the feeder but the printer says the feeder is empty
take all paper out, put half as much back in?
unplug, wait one minute, plug back in, might reset.
lastly, hp has an awesome trouble shooting site, check this out.
good luck
Apr 29, 2010 | HP PSC 1510 All-In-One InkJet Printer
My HP 7410 officejet keeps saying remove and check color cartridge. What can I do to clear this message and resume printing?
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers. take color cartridge out to see if anything is blocking the ink, might have a speck of dirt on it. put back in. be careful if you touch it the area of ink dispensary.
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome website for trouble shooting
hope this helps, good luck.
Apr 29, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP Color LaserJet CM1312nfi MFP printer leaves a 2 inch area unprinted using any programs. So basically it doesnt print the entire page.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Apr 29, 2010 | HP Color LaserJet 2600n Printer
Flashing light
turn printer on/off, unplug, plug in, should reset configs.
check the rollers to make sure no paper or particles are stuck.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome web site for trouble shooting
Apr 28, 2010 | HP DeskJet 3930 InkJet Printer
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
