How do i get the radio to go on scaner.does the radios get hot when charging.
I still dont know why the radis get hot when i charge them.If you can please tell me thank you.
Posted on Aug 02, 2008
New gmr 3055-2ck work fine just charming indictater on charge won't stop have charged twenty-four hours lights still flash
Make certain you are charging with the radio OFF. If on, the radio will use a small amount of energy and the charger will not know the battery is fully charged. If you intend to leave it on the charger, ON as in standby, then the lights will always flash. I would put a timer on the wall adapter so the battery is not always being charged. A battery always being charged will not last long, likely get hot and may cause problems. These are light duty radios, not designed for 24 hour if even daily use.
Jul 12, 2016 | Uniden Radio Communications
Why is the radio switching itself off?
Not knowing what brand or model radio, or how OLD it is, I have to say if it is powered by A/C electricity or by battery, then something inside is getting hot and it is shutting down to prevent further damage.
If running on battery power, maybe the battery or 1 of the batteries has gone bad?
Is the device charged with a cable?
Maybe it is not charging.
Faulty cable?
Is the charging source faulty?
Feb 03, 2015 | Audio Players & Recorders
Service engine light is on
It may be a false code, a small simple problem, or a very complicated an costly problem.
The first thing to do is to decode the light, and get the code explanation. After decide to clear the code or fix the problem.
You can use a code scaner, or visit local AutoZone to decode and find the code explanation, for free.
If you decide to clear the code, use the code scaner. You can clear the code by disconnecting the battery for a couple uf minutes and reconnecting. If you do not have the radio code, then you wont be able to actvate the radio again.
Oct 31, 2010 | 2005 Dodge Magnum
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
I have a loose connection where the AC power adapter fits into a Uniden XLTI20 SCANER where can i get it repaired in Geelong Victoria
most anyone who does radio or electronic work should be able to re solder the jack back into place. If you live near a truckstop, try there to see if they have a radio shop.
Dec 13, 2009 | Uniden BC248CLT Base Scanner
Where can I get the PC/IF cable for the Radio Shack PRO-94 Scaner
The cable works with many PRO-series scanners, and is still available from Radio Shack. Here's a link to their catalog page:
http://www.radioshack.com/product/index.jsp?productId=2177609&cp
Nov 13, 2009 | Radio Shack Pro-94 Scanner
Need radio unlock code 99 olds aurora
They are all random codes that are stored in the radio. The radio can lock it's self with possible 10.000 differant codes. You will need to take it to the dealer to have them use the gm scaner to retreive the code that is in the radio then they call the gm headquarters and those egg heads give an unlock code for the car. All of the make since?
Oct 13, 2009 | 1999 Oldsmobile Aurora
What is the police channel
sorry but an average D/C radio can't pick it up. do you think the cops are stupid enough to have an average joe (no offense) pick up a radio scaner/D/C radio and let them get tracked. they learned that lession a long time ago. the average d/c radio gose from 550 -1400 the cops are out side of that rang, all the time. Also it changes from city to city/districs...
May 30, 2009 | Radio Communications
Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 06, 2007 | Radio Communications
24 people viewed this question
 Grubhead
Grubhead
