Question about Toshiba 2060 Copier
Black line at top of copies
All of our copies have been coming out with a thick blak line across the top. If we lighten the copies, it is better, but then the copies are too light. it is otherwise working fine and we don't want to give it up because it is quick.
  • Anonymous Mar 13, 2014
    copying and scanning thick black line across page
  • Toshiba Master
  • 2,794 Answers
You could have a scratch on your drum. If you take a look at it inside the machine, see if it appears on the drum.
Posted on Jul 31, 2008
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
When you run a copy it leaves a couple thick dark lines on the paper that you copied too.
If you lighten the exposure do the lines fade away ? It most likly needs a drum or a drum cleaning blade. Good luck.
Jul 14, 2011 | Sharp AR-162S Copier
Thick black line appears 1/2 way across image when scanning
Try to wipe the scanner bed/glass with a soft cloth. If problem continues and the thick black line also appears when making a copy, it could be hardware problem. Then you will need to contact Lexmark technical support for additional assistance.
Apr 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Mar 16, 2009 | Sharp Office Equipment & Supplies
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
Line across my laptop screen
The graphics part of the laptop is going out. Recommend just replacing the laptop, it would be cheaper.
Jun 10, 2017 | Computers & Internet
157 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
