Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Clicking sound fridge freezer not running
I read the information on the clicking through the other posts and thought they were helpful, but I need more information, please. I have a GE model #GSH25JSRFSS.
There is a clicking on the mother board--does that mean the mother board is completely bad or do I need to replace a part? Also where would I buy a new mother board?
I also looked at the control panel on top of the freezer under the door hinge. One part is plugged in, but the other part has nothing to plug into. What is that good for?
Thank you,
Alex
  • Anonymous Aug 10, 2008
    refrigerator is not working , just a cconstant clicking sound
  • 172 Answers
Hi alexaz97,
First off the wire under the hinge is only for trouble shooting and should be fine. The control clicking on the other hand is usually a bad sign. The relays on the board should not click on and off, I have seen this about 10 times this month at my appliance store. The board will need to be replaced. If you would like I can send you a control board. I have pleanty in stock and ready to ship. The control is $124.99. Shipping is included. You can contact me here or at my appliance store.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
Slight smoky smell and freezer food/ice taste smoky
sounds like your motor is is burning out or someing inside the fridge is burn
Nov 19, 2013 | Kenmore Refrigerators
Difficult fault on samsung side by side fridge freezer SRS615DP
the problem must have been solved by the replacement of board..
i think you must consult the mechanic again for this
Aug 19, 2008 | Refrigerators
Fridge Won't Cool
First off that "condenser fan motor" needs to be replaced. It is not running near the speed it needs to. (I replace those all the time on the job) Here is the replacement to order.Also, based on the information you provided, it sounds like the main control board is sticking in defrost and you will need to replace the main control board on the unit. GE has an updated control board that address's this problem along with some other issues the original control board had.Here is the updated board to order.
All the parts come with a 365 day, any part, any reason return.
Keep me posted!
Nov 01, 2012 | Refrigerators
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Fridge not working freezer is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Temperature Display, Clicking Intermittent, Lost all Cooling
unplug the fridge and turn it around so you can see the compressor, does it have a capacitor located on the compressor (a round cylinder with wires comming out of it going to the compressor) it sounds like that could be your problem. They are pretty easy to change just a couple of wiers, just take note of where they go when you take it out. Make sure its unplugged from the wall before you do anything!
Feb 20, 2009 | Refrigerators
Trio 596.76502500 Mystery Noise
Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Aid Fridge problem
ok first the freezer does all the cooling for the whole unit and in order for it to cool properly the freezer needs to be a certain temp it should be around -10 -6 if its not reaching that temp it will still freeze and apper to be working right also check to hear if the freezer fan is running as it pulls air from the fridge and cools it then blowes it back look in the freezer on the back wall toward the bottom see if frost is building also in the refridgerator section on the left hand side of the cabnit is a return vent make sure its not blocked and see what the thermostat in the freezer is and let me know we need to know things like this to help narrow the promblems and people dont reply to the questions so we cant answer appliance repair is a skill
Jul 13, 2008 | Refrigerators
Fridge keeps ticking when not running???
Kevin, I'm going to give you a few scenerios to check out. The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise. Check your condensor fan, in back and make sure that is not hitting the shroud. If the overload on the compressor is tripping it will make a clicking sound, but it would be about every 4 to 5 minutes. If the unit goes into defrost, the evaportor coils tend to make a clicking sound. If you can be more specific as to where the noise is coming from, we might be able to help you better...Catriver...post back.
Aug 14, 2006 | Whirlpool ET9FHTXMQ Top Freezer...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
