Question about Kirby G5 Bagged Upright Vacuum
Bobbing up and down?
Hello! My stepmother's G5 bobs up and down when pushed certain directions on the carpet. She has tried to adjust the height when this happens, but it's as though the highest height keeps this from happening. Any suggestions?
Thank you!
Its more than likely the pile of the carpet is a little tighter in some areas of the carpet than it is in others. and, then you have to concider the grain of the carpet. I know your going GRAIN ?? what the ??? and scratching your head but yes even carpet has a grain. mine does the same thing and i have noticed that when i change directions over the same area it will not bob.
Posted on Aug 04, 2008
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Suction is great. However, it is very hard to push on carpet. Can this be adjusted?
Hi, this is Jim with Crucial Vacuum,
I'm unsure as to the make and model of your vacuum, but many different vacuums have height adjustments, and various carpet modes to make it easier when vacuuming. These adjustment options should be clearly labeled somewhere on your vacuum.
For instance, if you have the adjusted height set to low the brushroll will experience more resistance from the carpet and be harder to push. You can find these settings and their full functionality in your vacuums manual.
You can purchase a wide variety of replacement parts for your vacuum directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 02, 2015 | Vacuums
Why Vacuum suction too strong and can't push
Sometimes vacuums are adjustable as to how far down they sit. Some, if all the way down, are too close to certain carpets which has them getting sucked/stuck in place. I'm not familiar with your vacuum, but you might check the height setting.
Aug 08, 2014 | Dirt Devil Vacuums
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
How do I adjust the power cam locationpower cam on a dc27
Hi Charles, it's Jack at Dyson.
DC27 is engineered to adjust automatically for different floor types - there is no way of manually adjusting the height of the wheels or brush bar. The vacuum may need higher push force on certain types of deep pile carpeting. We would recommend checking directly with the carpet manufacturer for their advice on caring for this particular carpeting - manfacturers may recommend vacuuming some carpets with the brush bar turned off, and it may be worth giving this a try.
To turn off the brush bar, just use the brush control switch next to the red on/off switch:
Jun 19, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
We love our Dyson DC25 Animal but we just got new carpet and it's like pushing furniture around the room. I know it doesn't have a height adjustment but is there any other option?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 Animal on this particular type of carpeting. This sounds unusual especially as it worked effectively on your older carpeting. As DC25 is engineered to adjust automatically to different floor types and pile heights, there is unlikely to be an issue with the vacuum itself.
It may be worth checking directly with the carpet manufacturer for their guidance on caring for this specific type of flooring. Manufacturers will sometimes recommend vacuuming certain types of long-pile or delicate carpeting with the motorised brush bar turned off.
If you'd like any further guidance from our experts, you can reach us by calling the Dyson Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 11, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Adjust height for plush carpet
The best solution is to change your method of trying to push the vacuum. The more upright the handle is on an Oreck, the harder it will be to push. The lower the angle (the closer the handle is to the carpet) the easier it will be to push. There will be a huge difference. Use a straight stiff arm that is pointed directly down towards the carpet. Use your shoulder and have a near locked elbow. The vacuum will now push easily.
Jan 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
53 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
