Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Ddr ram Hi, install 1 gig ddr with the original 256 ddr, burnt ddr slot, pc wont boot. no bios messages, no beeps, no display, would you think the motherboard is damaged
  • 327 Answers
Welcome to fixya
if something burnt out most of the time the mother board is gone (junk) if nothing eles try to remove the new memory and try to reboot if still nothing happens then you fried the motherboard
sorrry to hear this
have a good day other wise :)
Posted on Jul 31, 2008
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
Dell 6000 Inspirion wont boot after trying to replace RAM
use ac power
try the 1 gig in each slot make sure it's secure.
If system still won't boot
then restart and try to get into bios setup
then set to default settings restart
if still not successful then replace the old ram make sure it's secure in the slots and restart
Then i would suggest taking new ram back and if you give them your make and model they can suggest ram for you
Feb 15, 2009 | Dell INSPIRON 6000 CENTRINO...
Iupgraded my memory and computer will not recognize slot 2
Don't worry about what Windows says...check your BIOS. Also the other stick must match in type ddr in speed exactly for it to work. Last choice take it out and reseat it. If it doesn't work or if the ram is damaged you will hear 4 very long beeps when you start up.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Pc will not boot
Make sure the ram is seated properly and in the slots correctly. If you are using more than one chip, use only one to start and then add any others yoiu may have. I think you will find a ram slot is craked or the chip is inserted backwards. You really cannot damage a M/B by adding DDR instead of DDR2. It really just about the bus path and bus speed. Double check our work.
Sep 26, 2008 | Biostar K8M800 Micro AM2 Motherboard
RAM problem
Hello, if you have an intel m processor for your sony then u are somewaht out of luck. the base memory is 256 megs and it is not in the motherboard but rather integrated in one of the slots itself, that means if u put a 512 mb chip into that certain slot it will only read 256. a lot of people are mislead into thinking they can put two 512s and get a gig of memory, but not true, at least not with most of the sony intel processors. find the base slot by switching chips around, then leave the 256mb chip there. then u can add a 512mb to the expandable slot and get over 700bytes. if u can find a 1gb compatible stick,then try that the same way, leave the original hynix base slot chip in and add the 1gb, if u can find one, then u will have a little over 1280 of which u can up the video graphic usage up to 128 in the bios, and have your 1gb in memory. if u find a 1gb memory chip that work,drop a line as to what brand and size u used
Jun 22, 2008 | Sony VAIO K45 Notebook
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
93 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
