The laptop has a slight discolouration on the bottom left hand corner which wasnt there before
    Sergeant:
  • 291 Answers
Do you feel HEAT! ? Dose the laptop work? Any problems that u detect>? Then no problem.
Posted on Jul 31, 2008
Large black transparent strip is appearing on my Samsung UA40D5500
This is a known issue with this Samsung TV.Problem maybe temporarily solved by twisting left hand top corner and bottom right slightly.
Permanent solution is replacement of panel.
Samir
Aug 18, 2013 | Televison & Video
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
My Hitachi 50UX26B/27K red picture tube seems to be out of line with the blue/green tubes. When I press the magic focus it runs a short 30 second cycle then displays the number 3 in the bottom right hand...
Your convergence is fried go to ebay and order this item number 130475189383 copy n paste and put in ebay search.You will also need a delsolering iron, a soldering iron, some kind of skill soldering and patience.
Jan 18, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
HP TX1000 Tablet The cursor on my screen keeps going to the bottom left hand corner and stays there. The problem remains even when I used a USB mouse. Anyone knows what the cause?
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
Jan 06, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
The screen on my tv has two slightly discoloured vertical bars
Sounds like image retention. Is it an older Plasma TV?
Image retention is when an image left is left on for a while actually "burns" into the image. It would be especially noticeable in BluRay because it is a bright image. The burn in was probably cause by watching Cable in 4:3. Try to find a static white image to display over night that should remove the burn in.
Nov 25, 2009 | Samsung Televison & Video
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Blue screen
no sounds on tv
Feb 25, 2008 | JVC AV-27260 27" TV
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
