Question about Sony XAV-7W 7 in. Car Monitor
Monitor won't open or close
This just happened yesterday when I turned the car off and the monitor would not close.
  • jagdamac205 Feb 07, 2009
    front funcion display lights went off, and moitor wont open but when it does it closes properly
    Champion:
  • 232 Answers
THE SMALL ELECTRICAL MOTOR THAT CONTROLS THIS FUNCTION IS MALFUNCTIONING. TRY TO RESET THE UNIT. IF THE UNIT HAS BEEN PREVIOUSLY RESET U MAY HAVE TO REPROGRAM THE UNIT TO CLOSE WITH KEY OFF.
Posted on Aug 28, 2008
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
When I shut my laptop monitor goes off and won't come on until I open laptop again?
Change display settings in energy management to NOT turn off when closing the laptop
Oct 20, 2012 | Apple Cinema Display 23" HD Monitor
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
LG w2361 monitor doesn't turn on at startup
Try hooking it up to a different computer and see if does the same thing.
how old is your monitor? You have 3 years warranty on it. Contact LG if you are still under warranty.
It could be your power supply on your monitor going bad. If you have some experience with electronics then open up the monitor and open the power supply and check for bad capacitors..If they are bad then replace them with same or higher capacity.
Apr 01, 2010 | LG Flatron W2242P-SF 22" Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
My 740N Samsung monitor is auto sleeping
either mobo or video card, try resetting cmos on mobo
Jun 02, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Monitor went black
This is a very common problem,
Most monitors go due to the connection, for example when you open and close the lid this loosens the connection so this is your problem.
You may be able to find and download the service manual on google, and take it step by step from there or take it in for a service.
hope this helps
alex
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Sony XAV-7W 7 in. Car Monitor Logo
164 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
