Question about Cuisinart Thermal DGB-600 Grinder
Spring Unscrewed the spring cover. Now I can't make it work so that the door opens and closes when I push it in.
  • Roger Buttermore
    Roger Buttermore Dec 04, 2008
    The basket door pops open during brewing cycle. I unscrewed the spring cover beneath the tray, attempting to remove the whole assembly for cleaning. Not only won't the tray assembly come free, now I can't re-install the spring, screw and cover in the right order and/or position. I need a schematic and assembly instructions, please!
  • 8,596 Answers
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
Door closes but stop in close position (jamm}
Has the spring at the top broken or come unwound? The spring helps pull the door open and the unit will not work unless the spring is working. Pull the cord and unlock the door from the opener and try to push it up by hand. If it is hard to push then you know the spring is not working. if its an older door the springs could be on the sides.
Sep 26, 2016 | Building Materials
The soapcover opens when I close the front door.
The spring on the soap cover is not pushing the catch tightly enough to keep it closed when there is vibration of the top cover of the machine. Remove the spring if you can and stretch it out a bit and remount it. Otherwise, replace the spring.
Jan 01, 2013 | Asko 24 in. D3350 Dishwasher
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
How do you open the left cover to remove a jam
open the front cover, pull the handle on the left door,see if paper has jammed between the rollers,remove the paper by turning green knob in the left front side. close the covers.if jam is not recovered follow the steps given below;
1, check if the sensor arm spring is detached (sensor is under side of fixing unit behind the left cover )
2, set the sensor spring correct take care not to overtighten the spring.
3, apply some rubber based adhesive to both spring ends so that it wont come out again.
close the doors and check.
Feb 06, 2011 | Canon ImageRUNNER 330s Copier
Cuisinart grind and brew pot - door holding filter pops open during grinding/brewing.
There is a little cover over a spring. The loops of the spring go inside the screw that holds the cover. The spring ends are against the wall and a small pin connected to the button on the side. Keeps the button locked. Cleaning out dried coffee in the are may help and pam spray may keep it from sticking.
Oct 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Soap dispenser unlocks but won't open
unscrewed and opened inside of door panel. Saw that spring was out of place, fixed, and reclosed. Working now.
Oct 26, 2009 | GE Dishwashers
My 96 lincoln mark viii gas door will not release when i push the button to open it. I have to have 2 people to go to the gas station, one to push button one to push on gas tank door to open it.
There is A Spring or Spring type Mechanism At the Door that POPS the Door Open Once the Button has been Pushed . And when you Close the Door This Same SPRING ACTION Sorta Fights Against your Closing it. Well it Sounds to me as if this Spring Action is Not Working Properly,
Take a CLOSE Look at this and Be sure This is Working Properly, My References Do NOT Go into DETAIL on this so its Kinda a Common Sense Approach to it.
Jul 15, 2009 | 1996 Lincoln Mark VIII
Front cover is open
the door of your printer have a micro switch ,on the door you have a some plastic part that prees that switch,try to find it and then put some plastic on the top .
Feb 01, 2008 | Brother MFC-9420CN All-In-One Laser...
Cuisinart Thermal DGB-600 Grinder Logo
109 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
