Question about Panasonic Office Equipment & Supplies
Panasonic UF4000 when receive some faxes just get blank pages
    Genius:
  • 2,120 Answers
Someone is sending you blanks.
Posted on Aug 31, 2008
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
Fax in memory is full. also the fax i received is blank. I had the sender to send multiple times, and its still blank.
OK...I'll ask a dumb question....have you tried to make a copy on your machine.???? If the pages are still blank, just a thought would be to check that you havn't installed the roll of paper in upside down.
Sep 27, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
Person receiving my faxes are getting blank pages
your ccd is shot... this is the piece of equipment that actually scans the copies.... its the component under the rectangular glass ****.... a tech needs to replace it...
Dec 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Received pages are cut off
This problem sounds like you have a NOISY or DIGITAL phone line. Press the MONITOR key and listen to the dialtone. It should sound static-free
Your fax machine needs a dedicated ANALOG phone line for optimum performance.
Jun 09, 2009 | Panasonic PANAFAX UF-6000 Fax
Blank pages
sounds like the contacts on you toner cartridge are not making contact. on the left side you will see 2 wire sticking out clean thoes and clean the metal contacts on the side of the toner cartridge
Jul 31, 2008 | Panasonic UF-4000 Printer
Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
67 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
