When I washed my razor head all of the parts fell out of the head. I now have a base with three holes, three gear wheels and the three covers. How do I put it all back together?
Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
Plug the power cord of the cleaning base into and electrical outlet.
Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
5
Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
6
Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
7
Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
To replace this part, locate the two holes at the front of the top base of the ice maker, going up into the freezer ceiling. Place the two half-round 'pegs' at the top of the missing cover (above the vent holes) into these holes, then press the cover back into place. The peg protruding from the back of the piece should go into the hole in the ice maker housing, and the prongs will catch on the ice maker when you snap it into place by brute force. I wasn't strong enough to push it back on with one hand, but a stronger person did it in seconds once I explained how it should fit.
That spring connects to a slot beside the height adjuster knob and a hole in the base to the wheels that fell off.The problem is you can't get the wheels to go back in flush so the height adjustment works.The vacuum will not be close enough to the floor to get any type up suction or brush contact.To change that spring as well as the belt,remove the cover by taking out two screws,one on each side.Force the rller out by prying the right end out of the slot.
Timing is aligned with bolts through holes in the drive wheels under the timing cover and a mark on the crankshaft remove the timing cover turn the crankshaft until the mark is at the top. the engine has treaded holes behind the drive wheel's get bolts(12 or 13mm head metric tread 4 or more ins long) push them through the holes in the wheels and screw to the engine this is alingment in an isuzu engine
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
This has happened to me several times. You just slip the metal tab sticking out of the blade assembly ( the flip up part} back in the slot until it snaps in to place.
