Refrigerators Logo
Posted on Mar 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Mar 11, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10844345
Points
101584
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2answers
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Everything is working but fan in frezer everything in bottom not getting cold it is a o5 model the name is kenmore cold spot model #106.74254400 type 22tfa
If understand your problem as being a bad fan in the freezer. Take the plastic or metal panel off that covers the back of the freezer. Inside you will see a fan that is held on by two or 3 screws 10mm or 5/16. Unplug the wires to the fan and remove the screws. This is an easy fix just make sure you unplug your fridge first. Hope this helps you.
1helpful
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Frezzer works refig not getting cold
sounds like it is a fan issue - there is a fan the blows the cold air from the freezer section in to the refrig section, stick ur head in the refrig section and see if you hear a fan running - you probably wont - you will actually probably start to notice that the freezer section is getting really really cold, like to the point of a deep freeze... the good news is that as long as the freezer section is cold your compressor is still working, so this will not be all that spendy to fix...
Kenmore cold spot
The reason to this problem can be due to the
faulty defrost.
1helpful
Problem with everything freezing inside icebox no matter where the control is set.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
2answers
Maytag side by side
all the cold air is made in the frezzer section then blown to the refrig section, the frzzer needs tobe -5 or 0 degrees F, also post model and serial number
alot of time people think if it freezes water it is cold but that happens at 32 F
2answers
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
