Question about LG LRFC25750 Refrigerator French Door
MAKING A LOUD NOISE WHEN THE DOORS ARE CLOSE. WHEN I OPEN THE DOORS THE NOISE GOES AWAY. THE NOISE DOES NOT GO AWAY IF I OPEN THE FREEZER DOOR.
  • 1 more comment
  • tironeh2 Jul 31, 2008
  • Anonymous Mar 29, 2009
    creda fridge freezer makes a whining noise and a grinding noise which goes away when door is opened
  • Anonymous Mar 14, 2014
    remove icemaker from LG french door refrigerator
I have the same problem. But the noise is not high pitched squeal as stated by 22yooper. And why would turning on the frig door switch affect the freezer section (which is in a separate compartment from the frig and it's doors)
Posted on Apr 03, 2010
  • 828 Answers
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
We have a LG french door refrig, Model #LRFC25750TT. Ice forms in the bottom of the freezer which causes the door to stick when opening and closing. It appears that water may be coming from the vent on...
You have a frozen drain tube. Remove the back cover after unplugging the unit. Locate the drain tube running down to the drip pan. If it is frozen, thew it with a hair dryer. In the inside, find the drain hole and pour hot water in it until it drains properly. I f it happens again your defrost element is too far away from the aluminum drain pan and needs to be GENTLY lowered closer to the drain
Dec 03, 2010 | LG LRFC25750 Refrigerator French Door
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
2 questions
Remove the drawers and locate the small round vent hole on the lower back wall. Place a piece of sturdy tape over the haole and re assemble unit...problem solved.
Dec 21, 2009 | LG LRFC25750 Refrigerator French Door
Light stays on when door closed
Make sure the wires are plugged into the door switch by prying it out. If it is plugged, replace the switch.
Oct 10, 2009 | LG LRFC25750 French Door Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Freezer door wont stay closed.
If you can pull the freezer drawer out, check to see if there is anything on the floor of the freezer. You can also try reinstalling the drawer. When you take the drawer out make sure that the spring loaded door catches on the sides are facing towards you. That is if it has any.
Dec 02, 2008 | LG LRFC25750 Refrigerator French Door
LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Sep 10, 2008 | Refrigerators
LG LRFC25750 Refrigerator French Door Logo
2,001 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
