Question about Panasonic KX-TGA101S Cordless Handset
Dropped calls - Model KX-TGA101S
Hi - I have been having a problem where during calls the call gets dropped - I can still hear the other party but they can't hear me or the line just goes dead. We do have phone service through Comcast and do have a wireless network in the house. I did unplug the phone and removed all batteries then reconnected everything (read somewhere it might help) and it did help for a few days, but...
I'm just not sure where to start. I have not called Comcast yet, but I definitely need to do something. Any help anyone could provide would be appreciated.
  • Panasonic Master
  • 19,396 Answers
Try replacing the phone cable, and check that is well plugged into phone rj11 connector.
If it is not the cable call comcast.
Posted on Jul 31, 2008
  • Ginko
    Ginko Jul 31, 2008
    If it is not the cable call comcast and verify that is not a problem on their line.
    Try also to find out if line drops or if they keep hearing you at the other end of the phone, in this case it is a problem with your phone speaker.
    Check your phone guaranty, if it still covered get a replacement unless you fix it with suggestions above.
What does it mean when phone is on desktop loop
Hi Shaundra,
A loop line or loop around is a telephone company test circuit. The circuit has two associated phone numbers. When one side of the loop is called (side A), the caller receives a test tone of approximately 1000 Hz(milliwatt test). When the second number (side B) is called, it produces dead silence, but the party on side A hears the milliwatt test tone drop, and is connected to the person on side B. The purpose of the loop around test is to allow circuit testing to a distant central office without needing a person at the far end. The technician can send a tone down either line and measure the response tone on the second line to determine the path loss parameters.
Sep 17, 2015 | Computers & Internet
How do I conference call
You may download the user manual part 1 and part 2. The conference call instructions begin on page 51 of part 2.
Feb 20, 2013 | AT&T ATT-974 Corded Phone
How to do conference call
Depends on the phone system or service you are using. On a regular land-line you can do a 3-way call (if you have this option available to you through your service provider). To do this:
1. Call the first party.
2. Once the caller is on the line ask them to hold while to connect with the 2nd party.
3. Flash to dial tone. There may be a flash button on your phone or you may just press talk. In any case you should hear a quick "beep..beep..beep" then dial tone.
4. Now you can dial the 2nd party and click the flash (or talk) again to return to the 1st party and you both should hear the phone ringing for the 2nd party.
There's hundreds, if not thousands, of different phones, phone systems, and provider combinations that have different procedures for making conference calls. This is probably the most basic way. Hope this helps
Nov 27, 2012 | Lands Phones
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
Hi i have a samsung mobile model s8003, am i able do conference calls from this mobile
during a call, once connected hold the other party and make new call, once connected to new party which you are calling, press more, select transfer and switch on your speaker so you can hear them and you can talk the same time with them, the disadvantage of this is, you will be the one whom get deducted through call charge.
Jan 28, 2010 | Samsung Jet S8000 Cell Phone
Dropped calls
Panasonic KX-TG9341T DECT 6.0 -
Both the BASE and the Handset DROPS OFF in the middle of a converstaion.... I CAN HEAR the Other Party talking, BUT they CANNOT HEAR ME... Very Strange...
Mar 26, 2009 | Panasonic Lands Phones
Unkown Beeping During Calls
It is hard to tell if this conference phone is installed on a PBX or not? "At meetings" tends to make me believe that it is. Beeping can come from a few sources. If a call is being recorded it is necessary to provide a beep tone so that the parties on the line know that they are being recorded. This is a FCC requirement. You can ask the other party if they are recording the call. Beeping can come from call waiting. It is recommended to turn call waiting off unless you are bridging incoming calls. If a call is on hold you will get a beeping tone. You can check by pressing the flash button and see if there is a second call. If so hangup and your original call should return normally.
Mar 21, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Panasonic KX-TGA101S Cordless Handset Logo
447 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
