Question about Philips Televison & Video
Tv struck by lighting
I have a Phillips 27PT5445/37 TV. I believe that it was struck by lighting yesterday. It will not turn on with the remote or at the tv. I hvae tried changing outlets and still nothing. Is there anything that I can do or try myself.?
Do you know anything about electronics ? Do you have a multi meter to check parts out?
Posted on Jul 31, 2008
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
Nov 29, 2016 | Panasonic Televison & Video
I need the codes for a phillips universal remote to control a toshiba TV.
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes:517 419 512 613 719 112 506 111 618 627 437 041 891 802 111 313 715 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Televison & Video
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
WHAT IS THE UNV. REMOTE COAD FOR THIS TV
here are the codes for a phillips universal remote for your tv 0421 1608 1004 1903 0216 0520 1515 and 1912 if you have a phillips universal remote thats fairly new like 2008 i believe then all you have to do is hold the setup or codesearch button until it turns red and enter in the four digit code hope this info. helps
Feb 27, 2010 | iLO IWT3206 TV
Closed captioning issues
Hit The PIP Button On The Remote Until It Says CC OFF
Feb 15, 2008 | Philips 25PS40S 25" TV
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Phillips 27 inch tv
did you check remote like battry, loose nothing is deposited near battry contact etc. if it is getting on from front board and not from remote then fault is due to remote. but if does not start from front also then problem is inside tv. like power supply or horizontal section failure. please do not forget to check plug & socket.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
