Question about Baumatic 23 in. BDW13 Built-in Dishwasher
E4 message have been trying to clear the e4 message by leaving machine switched off for 48 hours but without success. have checked the machine now drains properly (it does), is there anything else i can try ?
Take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Posted on Nov 05, 2008
Sir E4 code open help me ifb aw60-8061
There is no matter with this error code. Just switch OFF the device and switch it ON only after 48 hours. It will reset itself. If the error code is E2, there is no need to make it right. It has gone. Buy an other one.
Aug 29, 2016 | IFB Washing Machines
Machine sticks and 'timer saver' flashes. When turned off and onto 'drain' the lights shown on the video flash.
Switch off machine for an hour, press down all the panel buttons to drain any residual voltage to the board. Now when the power is reconnected and the machine is switched on, press down Start/Stop/Pause buttons.
If the fault does not clear, then check for dirt in the inlet and outlet , check flow and drain without water accumulating within. If not the control board is a suspect
Jan 04, 2013 | Washing Machines
In my experience, E4 is appear when spin is starting. Then I check the 'magnetic door safety switch' and gotcha, I find the problem --> 'magnetic door safety switch' is damage (always open). Because some reason, I am short-circuit it. Fixed.
Oct 11, 2012 | Washing Machines
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
Hi, Bosch WAS28720FF/01 Washing machine sometimes empties and sometimes does not. "Pump blocked" is the typical error message. Pump and drain tube have been inspected and cleared, and there is...
Bosch WAS28720FF/01 Washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 01, 2011 | Bosch Washing Machines
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Nov 06, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
239 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
