Question about RCA DRC200N
Frozen player The Tv is on and set to AV2, Comcast cable is fine, but the player will not respond to any command. I cannot turn off the RCADRC200N manually or with the remote. I will try to replace the remote's battery when I get to a store, but also thought there may be some other secret to unfreezing the equipment. a DVD is in the player. Thanks.
Try this: reset player by pressing & holding the standby/on button while you press & hold the stop button. Hold for at least 15 sec.
Also try: when unit is plugged in, remove from outlet for at least 5 min. Then plug it back in.
Posted on Nov 20, 2008
My tv is an Emerson 20" HDTV. Last week the closed caption just popped on and we can't get it off. My cable company, Comcast, said my box is not equiped to support closed caption so it is the tv....
I think Comcast doesn't know much about their equipment; their box has no influence on CC since it is embedded in the program material and is passed through their receiver to your set. There are two possibilities; the remote is no longer sending the pulse train to control CC or the set's receiver isn't responding to that command.
You can do a rough check on your remote if you own any kind of digital camera; still or video. Turn on the camera so that you have a display picture of the room you are in. Point the remote toward the camera's lens and push (and hold) a button on the remote that you know is working, such as the "Power" button while looking at the LCD display of the camera. You should be able to easily see the blinking of the InfraRed LED(s) which most all digital cameras can 'see.' Once you know what to look for, try the button that should control the Closed Caption function. If you don't see anything on your camera LCD display, that button (or the circuit it controls) isn't sending out the code train required to control that function. If that is the case, you may be able to buy an original ('universal' remotes really aren't) replacement remote from:
Remotes.com
Conversely, if you DO see the remote blinking, then the circuit in the TV set that responds to the CC (and others) command has partly failed and that is more costly to repair.
May 08, 2011 | Emerson CR202EM9 TV
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
Mar 04, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
May 01, 2009 | Apex Digital ADV3800 DVD Player/VCR
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the TV...video and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
RCA DRC200N Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
