Question about Whirlpool Duet GHW9150P Front Load Washer
Not solution i need
Coolgu,
I already opend the bottom panel and removed the filter. It was clean.
  • facelogicatl Jul 31, 2008
    Thanks. I unplugged it and ran a quick wash cycle. Now the door won't open. The door light stayed on. So I unplugged it and plugged it back in. The light went out but the door won't open.
    Genius:
  • 3,422 Answers
The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground.
Posted on Jul 31, 2008
  • 3 more comments
  • Priya darshan Jul 31, 2008
    F21 means long drain time,If you still face the problem then it will require a physical presence of a tech.
    F21 is:
    LONG DRAIN
    If the drain time
    exceeds 8 minutes the water valves turn off.
    NOTES:
    After 4 minutes the
    “Sd” error will be displayed, then
    4 minutes later the
    “F/21” error code will be displayed.
    Press PAUSE/CANCEL
    two times to clear the display.
    Possible
    Causes/Procedure
    1. Check the drain
    hose and make sure it is not plugged or
    kinked.
    2. Unplug washer or
    disconnect power.
    3. Check the
    electrical connections at the pump and make sure
    the pump is running.
    4. Check the drain
    pump filter for foreign objects.
    5. Plug in washer or
    reconnect power.
    6. If the above does
    not correct the problem, go to step 7.
    7. Unplug washer or
    disconnect power.
    8. Replace the pump.
  • Priya darshan Aug 01, 2008
    Remove the panel beneath the door (2 or 3 screws). Reach up, there is a
    little "ring" beneath the door lock. Pull this down, it releases the
    mechanism.
    Please CLICK HERE for the service manual.
    I suggest you to leave your washer unplugged for 24hours to allow it to reset and the door should unlock..If it doesn't then go for removing the screws.
    the door lock is removed by removing the spring around the
    rubber seal and then reaching behind it and getting the screw should remove door lock switch.IF this is broken then you will have to put it yourself.
    Anyways i gave you the service manual.
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F02 code on duet washer mean?
Jul 28, 2014 | Whirlpool duet Washing Machines
What does F 02 code mean ?
Normally a simple fix: Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out. With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out clean and install it back into washer. Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
May 04, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Machine stoped half way in to cycle fo5 appeared on display panel
You need to clean the pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose on bottom of drum.
Remove an clean plastic filter inside the hose.
Reassemble and test for leaks.
Jan 23, 2011 | Hotpoint Washing Machines
I have a LTF2940ES3 and the water drains slowly and not completely. I get the error code E20 and I have already checked the exterior hose and it is not clogged. I washed a stuffed toy pillow and it tore...
There is a filter in the black hose that goes from the tub to the pump. It must be where the toy stuffing blocked the water from draining. Access the hose through the front bottom panel then remove it from the bottom of the tub to get the filter out and clean it.
Remove the two screws attaching the front bottom panel to the cabinet then slide the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall to access the screws more easily.
Loosen the clamp holding the tub-to-pump hose to the tub to remove it and take out filter. Clean the filter then reinstall it and the front bottom panel in reverse order of the removal steps.
Jun 13, 2010 | Washing Machines
F21 code and leaking from behind washer where hose comes out. Already used shop vac to drain hose, got code again on cleaning cycle.
F21 is a code for Long Drain.check to see if anything is clogging the pump.If you remove the 3 1/4" hex screws from the bottom panel,you can remove the panel.Behind the panel is a large white pump.You can remove the filter and check to see that nothing is clogged inside.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking randomly under GE refrigerator
It sounds like you have a plugged drain tube.The easy way to clean it would be to unplug fridge over night with the doors opend to defrost then remove rear bottom panel.After that you should see a tube going into a drip pan clean the end and blown in to it with a air tool or if you wantt o fast clean the end and use your mouth.After line is clear you can pour hot water into freezwer part and see if it drains into **** pan hope i helped :)
May 11, 2009 | GE GSS25JFM Side by Side Refrigerator
Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Dec 15, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
