Question about Maytag Neptune MDG5500AW Gas Dryer
Gas dryer my dryer is heating but runs from 1-3 minutes and then shuts off
    Sergeant:
  • 229 Answers
There is an automatic shut off switch (that is a fire preventative) that is malfuntioning. These switches go out and are a pretty common problem. These switches are located on the inside of the dryer and are usually in the rear of the assembly. Unless you are really good with electrical appliances I don't recommend repairing this yourself. Call a repairman and if you sound fairly savvy - example: Hi I am having a problem with my Model xxx Dryer. It seems like it's one of the overheat kill switches. How much will it cost to replace?I just don't have time to do it myself right now. Etc..Etc..Etc.. you probably won't get gouged for too high of a repair cost. A skilled dryer repairman knows this is a simple repair and takes about a half hour tops. There are actually three of these "kill switches" in a typical dryer. They are redundant so that if the dryer ever gets too hot it will shut off and prevent fire AND litigation. Once it is repaired you will be good too go for a good long time again(depending on the quality of the model, of course). Good Luck!!!
Posted on Nov 07, 2008
Quietpak 4 gas dryer. Why does it heat for about 4 minutes, then shut off?
Could be a faulty igniter, thermocouple, and/or gas valve
May 26, 2015 | Dryers
Runs an stops need a heating element?
MAY WANT TO CHECK OUT UR THERMOSTATS FIRST. DOES IT STOP AFTER 30-30 MINUTES? THEN U MAY HAVE BAD MOTOR WINDINGS ? HEATING ELEMENT DOES NOT CONTROL SHUTTING OFF RUNNING. ONLY THE HEAT IS SHUT OFF?
Jun 29, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Our kenmore gas dryer is starting but after 1 minute the heat shuts off what could it be
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./'
Mar 27, 2011 | Kenmore 600 6965 Electric Dryer
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
The dryer runs fine but the gas comes on for about 1 minute then shuts off. It may cycle once or twice then stops. The vent is clear and I cleaned the filter assembly and the fan housing.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 15, 2010 | Maytag MDG6000 Dryer
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
85 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
