Question about Refrigerators
Freezer gasket dry
freezer gasket is dry, causing ice to form in the freezer. I understand that I can fix it myself but the instructions I find don't tell me how to find the screws that hold the gasket.
  • 1 more comment
  • Lorettaw Jul 31, 2008
    The gasket doesn't roll back without forcing something. Maybe it's not attached with screws?
    I still can't find the screws. How else might the gasket be attached? And could I, an amateur, do it? LorettaW
    I can't tell, or certainly can't describe it. Pulling the gasket from the outside corner it looks like it might be glued, or on a rigid frame of some kind that snaps in place. No wedge evident.
    It's a 3 or 4year old Kenmore model #7509 with a bottom freezer. Any ideas? Thanks for the help.
  • 828 Answers
Roll the gasket back from the inside edge and under it you will find screws if they were the method used to secure the gasket in place.
Posted on Jul 31, 2008
  • James Helmer
    James Helmer Jul 31, 2008
    Some door gaskets are attached by a wedge at its center. You can tell if this is your type beginning at one corner. Lift the corner and you can see under it how it is attached.
  • James Helmer
    James Helmer Aug 01, 2008
    Four years old is a short time for a gasket. they usualy last the life of the unit. You can sometimes soften them op by cleaning them with warm water and detergent.
There is water freezing under the bottom mount drawer. The ice is so thick that water is leaking out the front onto the floor. There is no information in the manual about troubleshooting this problem
Try to have it fixed under warranty.
If that does not work, here is what is usually wrong.
(I maintain a dozen of these and see this all too often.)
One day, the freezer drawer might have been left open, even for a short time.
I mean, not closed tight.
This causes warm air to enter the freezer, and then ice forms where the warm air met the cold air.
The ice forms in and around the gasket, which then keeps the door from closing tightly, which then causes more ice to form, etc.
After a good defrosting , and cleaning, (especially the gasket), see if a fresh start has fixed this.
If it happens again, you might need a new drawer gasket.
God bless your efforts.
Feb 27, 2018 | Televison & Video
How do I stop frost/ice from building up in freezer (bottom freezer of French Door Stainless Steel bought in Dec 2011)
Check the door gasket carefully for cracks or other leaks. It is crucial to have a good barrier between the moist room air and the super-dry air inside the box that will quickly suck in the ambient humidity and form frost.
It would be difficult to change the sensor and the heater, and if the defrost cycle is running (and you feel some warmth around the bottom of the box when it is cycling) then the sensor and heater assembly are working and do not need to be replaced. The best practice is to remove any frost buildup at regular intervals and often to prevent a thick buildup that is difficult to remove.
Nov 19, 2014 | Samsung RF26VAB (25.5 cu. ft.)...
Freezer defrost working but leeks
Hey friend, I appreciate the post!
I understand that your refrigerator is defrosting but you are getting a patch of ice to form due to water leaking inside the freezer. It may be a moisture build up in your freezer. Which may be caused by the door being slightly opened, when that happens warm air can enter the refrigerator and cause a moisture build up. You could also check to see if your door seal is bad, the way to test that is to place a dollar bill between the body of the refrigerator and close to the door. Pull the dollar bill out, if it sticks it is good, but if bill comes out easily the gasket need to be checked. Hope this is helpful- Matt
Jul 19, 2014 | Frigidaire Refrigerators
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Excessive "fog" in freezer causing
Check your door gasket. Cleaning the gasket should help it seal again
Nov 27, 2017 | Maytag Refrigerators
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice on top of freezer and top shelf of door
IT SOUND LIKE YOU HAVE AN AIR LEAK IN TOP OF GASKET,THE GASKET HAS A MAGNET IN IT ,YOU CAN USE A HAIR DRYER TO SOFTEN THE RUBBER UP TO SEE IF YOU CAN GET THE SEAL BACK TIGHT,BE CAREFULL NOT TO BURN THE GASKET OR YOURSELF,THANKS-MIKE
May 27, 2008 | Freezers
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
