Question about Dometic RGE400 Top Freezer Refrigerator
REfrig and freezer not cooling
My dometic refrigerator/freezer all of a sudden, stopped working. It will not work on elec or gas. Is there anything I can check before having to spend $ to find out it could be a small item I could have done myself?
  • stinaf Jul 31, 2008
    Thank you for your help. The unit is level. We have not had a problem with it in almost three years, and have had the RV not quite level before.
  • stinaf Aug 01, 2008
    Ouch, someone needs a hug!
  • 828 Answers
These unit must be level to function. Never side to side tilt but it is permissible to have it tilted a little toward the back. This would be the first step.
Posted on Jul 31, 2008
  • James Helmer
    James Helmer Aug 01, 2008
    Under certain conditions a complete separation of the working gases in these systems happens. The procedure to follow is: Remove the refrigerator from its mounting to a place with room enough to rotate it. Starting with the unit sitting on its base, rotate it to the door and wait five minutes. Next rotate it to its top and wait five minutes, then to its back and wait again five minutes, finally rotate it back to its base and wait five minutes. You can then apply power to the unit and see if the procedure worked.
    This procedure forces the water from its boiler to flow through the system in stages and finally returning to its original state. It forces the chemicals to mix so it will again work.
    As I said in my first post to you, it was the first step. You should not have rated it as thanks for trying at that time.
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Freezer & refrig not cold
change the filter. to do this recover the freon(gas), remove the filter , replace it by new one; do the vacuum and then charge again. Work must be done by a certified technician. do that at your own risk
Aug 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Refrig does not work on elec
there is a small fuse on some models and check you heater for a short
Jun 02, 2009 | Dometic RM2652 Refrigerator
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
187 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
