Question about Dryers
Have auto-sensing Estate dryer. Heats OK, but won't shut-off, auto or timer. I thought at first an auto-sensor problem, but on timer won't shut off either. Very strange...any help out there???
    Master:
  • 382 Answers
Does the heat still stays after the timer ends??...okie You can do a visual check on the element.Start by unplugging unit then remove lower back panel.on the bottom right you will see a metal box with a removable lower section should be two screws. Disconnect wires to element and limit stat,take out screws and remove element visually check coils make sure it isn't burned into or touching the metal case anywhere,don't be afraid to move it around with your finger check it out good .If it is broken you need a new one ...If it isn't broken you will need that meter or buy a thermal fuse kit for the dryer and gamble ...That is the next most likely .Regardless of repairing this one or a new one check vent very close make sure it has full 4" all the way out.Most of dryer heating problems start in the vent.BE SAFE UNPLUG BEFORE GETTING INSIDE! CHECK YOUR POWER ACROSS THE TWO OUTSIDE SCREWS WHERE THE CORD ATACHES TO THE DRYER YOU NEED 220 HERE YOU HAVE NEUTRAL/GROUND IF IT RUNS...
Thank you!!
Kind Regards!!...
Posted on Jul 31, 2008
  • Dryers Master
  • 19,396 Answers
You need to replace the timer insert model here to buy part.
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
No heat, timer not moving
Yes you need to replace the duct fuse and clear all air obstructions. I have repair photos HERE
Feb 17, 2010 | Kenmore 63942 Dryer
My Kenmore dryer (model # 11077732795) would not shut off or heat up. I replaced the timer and thermal fuse. The dryer now heats up and the timer moves but never shuts off. Any suggestions.
Just inside the drum on the front panel is a metal sensor strip that detects a change in capacitance as the clothes get dryer. When no more dampness is read the motor is energised by the moisture sensing board. Get the goop off the sensor strips so they can send a dry message.
Mar 01, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
