Question about LG WD-14124RD Front Load Washer / Dryer
LG TROM STEAM WASHER-WM2487 HRM
MY DAUGHTER HAS A SOUR SMELL IN HER WASHER. WE HAVE TRIED TO RUN A BLEACH AND SOAP WASH WITH HOT WATER WITH NO RESULTS. SOMEONE TOLD HER THERE WAS A FILTER SOMEWHERE WE MIGHT CHANGE OR REPLACE. THANKS FOR YOUR HELP IN ADVANCE!
    New Friend:
  • 60 Answers
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Posted on Jul 31, 2008
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Why does my frigidaire affinity smell
clean it by using 5 cups bleach fill soap cup put rest in tub wash in hot water long cycle run another or 2 after to make sure bleach is gone
Jun 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
My clothes stink so bad from my front end LG washer! My co-worker on my first week of work started buying bath and body sprays and body wash leaving it on my desk. I'm so pissed off because my washer was...
My LG stunk too. I did the tub washing with 1 cup bleach and wiping the rim, leaving everything open, nothing worked. I added 2 cups of a 6% bleach and used the tub cleaning cycle, rinsed with an empty hot water cycle then added bleach-able clothes to the 2nd hot water rinse (the third cycle/step). It gets a very strong bleach smell so don't take a whiff if you open the door in the first 2 cycles! After I did the strong bleach cycle, I am able to treat with just the 1 cup bleach about every 3 or 4 weeks and I make sure to wash with a hot water wash every week and a half at the least. This seems to keep my clothes smelling fresh like they should. Before I bought the LG, I read where people turned up the amount of water the washer takes in but I can't find the link that said how to do that. I think it was 1/4 turn on a screw on the top of the machine (when you take the cover off) but I can't guarantee how to do that.
Jun 26, 2010 | LG WM-2277HW Front Load Washer
Foul smell inn LG Washer
you need to remove the inner wash drum and clean out the outer drum of ALL the soap and softener in the outer drum so it can drain properly, as it has started growing mold/mildew in the outer drum,also while it is out clean the door seal boot and make sure the drain boot hole is clear too that drains to the outer drum so it can all go down the drain,then put it back together and hot wash an empty tub in hot water and bleach
May 15, 2010 | LG WM2487H Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Trom Front Load Washer
I have never heard of cooking oil but I have heard of vinegar. If you have had your washer for a while (over a year) it could take several times of cleaning to get rid of the odor. Also be aware that liquid softner actually builds up worse inside the tub then the soap does so only use 1 tablespoon of softner. If you run the washer with nothing in it and you see lots of bubbles in the water you still have the build up inside the tub. The last item I've heard of is something called "whirlout" (not sure on the spellng) that you can get from a hot tub dealer.
Aug 14, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Smell on towels
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Jan 18, 2008 | LG WM-2277HW Front Load Washer
Washer smells bad
There is a door on the bottom og this machine, I opened the door to find a little spot, I placed a bowel under the spout and opened it, drained all of the liquid out and this problem stopped! I also ran the machine on hot water with bleach after I emptied this resevoir. How often you do laundry will determine how often you must empty it. For me, once every 6-8 months does the trick!
Dec 08, 2007 | LG WM-2277HW Front Load Washer
LG TROMM WM2487 Bleach not getting fully removed after cycle
Keeping in mind that the bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water.  Is your cold water valve screen plugged causing your washer to rinse poorley?  Are you using the HE detergent?  If not maybe the washer is sudsing up to much and haveing a hard time rinsing all the suds and bleach out.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up?  Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is alot higher than the top of the washer it might have a hard time draining out all of the bleach water before the next load
Aug 26, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-14124RD Front Load Washer / Dryer Logo
350 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
