Top Loader? That sounds like a gearbox problem. It is not an easy fix. With that much use and those many years, it is probably time for a new one. A new High Efficiency Front Loader, will save you a fortune in water, electricity and detergent.
Try this forum though if you want to try and get it fixed.
Aug 21, 2009 - 10 posts - 5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Spin solenoid could have water leaking onto it and it stuck on , but noise is most likely caused by bearing getting water into them,dose it leek water on the floor?
What you want to do is first unplug the machine. With that done have someone tilt the machine backwards while you lay in front of it to look. You'll notice a white foam like bottom, which you want to pull out. Watch as you doing so because the next step. There is a nut that screws onto the bolt that the pulley slides on to. Its a manufacturer defect, and when I was doing first year warranty for whirlpool I'd get about three a week. My solution to it. Get the belt around the pulley, push the pullley all the way up to where its supposed to sit, get some lock-tight and place on the bolt, not too much, and put your nut back on and ratchet it tightly. I've had no recalls using this method.
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
