Question about Dell 962 Photo All-In-One InkJet Printer
Dell 962 The printer has been working fine for a couple of years. I might use it 2 or 3 times a week. One day, I went to make a copy and the printer went through its' usual process and when the sheet came out, it was blank. I tried putting a copy under the cover for a manuel copy and that came out blank too. In the past, when there was an indication that the ink cartridge need to be replaced the copies came out lighter and lighter. I checked all the connections and like I said, the printer went through the copy process like it was printing something but, was not. Thank you in advance. Frank Ganat
  • frankganat1 Aug 09, 2008
    I took out the color cartridge and it prints both ways(through the computer and manualy). When I put the color cartridge in the printer reads that the right color cartridge is not installed correctly.
    Genius:
  • Dell Master
  • 1,056 Answers
Have you tried to get it to print anything else? Like one of the internal reports, or just a document from your computer. That will determine if it can print at all.
Once you can establish that it can (or can't) print, then you can troubleshoot other items.
You did mention that you only use it a few times a week, it could be that the cartridge has dried up, or the print nozzle has become blocked.
Try the tests, and please inform.
Posted on Aug 01, 2008
  • Coss Aug 09, 2008
    First thing to try is cleaning the cartridge.
    Use something like a baby-wipe, or one of those hand wipe little pads that has alcohol.
    Clean in one direction only (like from the center towards the outside edge. Do this on both the print head area, and the contact points. Also go in, and clean the carrier (the part it plugs into).
    Next step would be to replace the cartridge. Make sure to use a Dell branded cartridge. For a few years now, they imbed "smart" chips into them. And will sometime just reject aftermarket refills.
    They also program in for some of the cartridges to expire after 18 months, doesn't matter if it's empty or not.
    Please inform if this helps at all.
My dell 962 printer was working fine. Then the next time I went to use it, the malfunction light was blinking and I had the message "right cartridge incorrect". I took it out and back in, unplugged and the...
You can try a new cartrige...and I would check to see if it's under warrenty. And there also a proccess for resetting the unit / master reset...it's in your product quide.
Thanks
Feb 20, 2010 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 printer power and function buttons not working
Hope you can find answers in the manual.
http://support.dell.com/support/edocs/systems/962/en/OM/962_English.pdf
Apr 06, 2009 | Dell 962 Photo All-In-One InkJet Printer
No disk 2 for a Dell 962
Well unless you are wanting the All-in-One solution cetner that comes on the CD,you can download the driver from the Dell website and I have includedthe link, but for some reason it does not take in this note, please goDell's website and look under support & drivers and the then put inthe model information and the driver will be there.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R92834&SystemID=PRN_ALL_A962&servicetag=&os=WW1&osl=en&deviceid=7348&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=40&fileid=128698
Jan 16, 2009 | Dell 962 Photo All-In-One InkJet Printer
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
2nd request - Dell 962 All-in-one Printer - from glass top
ok..start by removing the printer from your printer panel.
then go here for fresh drivers(not the CD version)
reinstall
hook up printer
see how it works
Mar 17, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 Photo printer
hmmm..interesting..sometimes, in the translation from one fax machine to another, the grey scale densities don't match up. So, your printer almost certainly has a higher resolution than a standard fax machine. Only way to do this is to test and attempt to balance it from one machine to another. Maybe you'll get lucky, and they will be compatible.
got backup?
Feb 18, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 copy & fax issues
Go to Dell AIO and click on maintenace/ Troubleshoot on top of the page. Then go to maintain or fix quality problems.
Then choose the problem and run it.
Nov 14, 2007 | Dell 962 Photo All-In-One InkJet Printer
My Dell AIO 962 Printer does not respond
The printer is dead and needs replacement. If covered under warranty, u can get a replacement from Dell. Speak to Dell support and they can give you alternative solution.
Nov 08, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
