Question about Biostar P4M800-M7A Motherboard
Cannot access the BIOS
My computer continually locks up on the intro screen which shows the motherboard heading. I have gotten past this by disconnecting the cables in the back, holding the power button for 30 sec. and rebooting. This seems to work. However, when the computer starts up, i cannot access the BIOS. It says to push delete to get there but that doesnt work. I have used both a USB and PS2 keyboard in case that was the problem.
i'd like to install a new video card, a GEForce fx5200 but cannot get the computer to boot after i have installed the card.
any assistance is appreciated.
Josh
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
when you first turn on the computer hold down F2 for a few secounds this should take you to bios screen and as for the new video card i hope you got a new power supply to no lower then 500w power supply with that video card if not bigger
i do not think the ps2 keyboard should be a problem....
hope this helps you out have a good day :)
Posted on Jul 31, 2008
Ecs 945gct m3 v h motherboard ver 3.1
Your motherboard keyboard controller is not initializing completely. The three LEDs shows the keyboard is powered and initializes, but the motherboard keyboard controller looks to be bad. I assume the keyboards work on other computers. Make sure there are no jumpers on the motherboard for the keyboard. You said the video screen is stuck on CMOS BIOS logo and is trying to continue with a missing keyboard or keyboard error. So since it got to the BIOS screen, pretty much everything else came up.
Jan 13, 2014 | Computers & Internet
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
How to setting the bios?
To access the bios on *********** board reboot your computer and Immediatly begin pressing the "Delete" button. Continue pressing the button every second until the bios shows on the screen.
Here you can change many settings that will tune your computer.
Thanks.
Nov 01, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Computer won't go pass intro screen
ok
when u power up the laptop press "del"or F2 or F5 to enter in bios .then load optimal defaults settings.then save and exit.
then check.
Jan 19, 2009 | Toshiba Satellite M45-S359 Notebook
Powers On But Freezes on Start-up page
if this is one of those special Toshiba's with the bios/cmos on the hard drive you're in a world of pain. Can you access the bios at all? Can you see the hard drive or what can you see if you can get in the bios? I could be wrong- but if you can't get into the bios you may have a corrupt hard drive- and need another one- or the motherboard could be bad, or the ram might be bad too.
Try starting with the getting into the bios- and see what you can find out...
Dec 18, 2007 | Toshiba Satellite L25-S119 Notebook
Sony vaio laptop will not move past 'vaio screen'
Are you saying that it gets stuck at the "Vaio" screen?
Oct 21, 2007 | Sony VAIO (PCWA-A200)
Start up problem
have you tried reflashing your bios chip with the latest bios?I think it's 0701,im not sure what socket you have so, you would need to go to asus.com go site at the top click "download" then next page look for "download on the right then enter motherboard your socket then model of your motherboard and follow bios flash instructios and enter your model etc,.it's easy enough then
Oct 06, 2007 | ASUS P5RD1-VM Motherboard
Biostar P4M800-M7A Motherboard Logo
107 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
