Question about Brother HL 5250DN Laser Printer
Toner light on - Brother HL 5250DN Laser Printer
    Problem Solver:
  • 7 Answers
Fixing this problem is very easy, even for those not so technical. All you need is a Philips Screwdriver. And it will also save you money in the process! :-)
The link above to the PDF has good images to help, so download that first.
Look at Fig. 5 on page 2. There you see 2 silver screws. Remove these.
Look at Fig. 6 and Fig 6a on page 3. Remove the cover and then remove the Flag gear (red arrow in Fig. 6) and the spring behind it as shown in Fig 6a.
Now replace the cover and the 2 screws! That's it! Yes it is that simple, just remove the Flag Gear and the Spring. The printer will keep on printing. This will also save you loads of money, as the toner can be used until really empty.
Happy Printing
Rigsby
Posted on Dec 01, 2008
Change your toner. if it's a rather new toner, it might not be your toner cartridge but you have to reset the toner cartridge's end of life flag gear, explained below:
http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
the Flag gear lines up with a flap on the pritner side. you can also tape that up to achieve the same goal.
Posted on Nov 20, 2008
Rigsby66's solution (removing the flag gear completely) was the only one that worked for me. Many thanks!
Posted on Jun 12, 2009
What is a toner light and what may of caused it?
Posted on Nov 19, 2008
Problem solved
Posted on Aug 01, 2008
Sharp Ar-5516 toner light problem continue blinking
If the toner light has a line under it your waste toner container is full and needs to be emptied.
May 04, 2016 | Sharp Office Equipment & Supplies
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
LIGHT COPIES WITH A NEW TONER CARTRIAGE
Was the toner sign on when u replace the toner bottle?
Dec 02, 2013 | Savin Compatible Copier Toner Black For...
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Have a problem with a Sharp AR152. The toner
Once the toner lite comes on it blows the chip in the toner cartridge, a new toner will fix your problem.
May 04, 2009 | Office Equipment & Supplies
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Toner light on replaced toner
probably broken toner motorshaft remove toner cartridge look to back of machine if you find a white collar and a spring laying on the bottom thats it
Mar 21, 2008 | Sharp AL 1631 Copier
Brother HL 5250DN Laser Printer Logo
3,251 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
