TS 2000 KENWOOD TRANCEIVER
I HAVE A KENWOOD TS 2000 AMATUER RADIO TRANSCEIVER WHICH I HAVE THE FEELING,HAS GONE SLIGHTLY DEAF ON RX.THE DEALER WHOM I PURCHASED IT FROM HAS TESTED IT AND RETURNED IT TO ME,QUOTE NOTHING WRONG WITH IT !! I HAVE COMPARED THE RX TO OTHER RADIO TRANSCEIVERS I OWN AND OPERATE AND THEY ARE MOST CERTAINLY MUCH MORE SENSITIVE ON RX !! ( I AM A FULLY LICENCED RADIO AMATUER )
THE TS 2000 UNDER WARRANTY,SO IS THIS A PROBLEM ANYONE CAN ASSIST ME WITH.IE:- HAS ANYONE THE SAME PROBLEM,IS THERE A CURE,OR IS IT DUE TO THE FACT THAT THE TS.2000 IS A"SHACK IN A BOX,A BLACK ONE AT THAT IT WOULD SEEM"
  • bob886 Nov 01, 2008
    Main Rx is about 20 dB worse NF than the Sub. Measured all bands 3.5 through 432 with 15.5 ENR source. Note I had done this when brand new and now it is ~ 20 dB worse also measured by 3 dB rise method with calibrated sig gen. I haven't opened it up yet - but appears to be at or after the 10.695 MHz Rx stage from looking at the service manual, as that is where the upper band front ends are mux'd in with the HF-50 MHz front end.
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Posted on Jun 15, 2010
A lot of TS-2000 radios suffer from attanuated receive, it is caused by a design problem of the transceiver.
The cause is leakage within the 455KHz ceramic filters, the manufacturer states in its datasheet that coupling capacitors should be used and Kenwood,in its wisdom opted not to bother to fit the required capacitors.
The Toko filters are not easy to obtain and may attract a lengthy lead time.
Posted on Sep 08, 2009
I have the same problem my sub band receve minus signals in the meter how i cand fix ?
wp4nff@hotmail.com
Posted on Sep 27, 2009
I had a similar problem which turned out to be high resistance contacts on the K3 relay which switches the inbuilt antanna tuner in or out.Go into the menu Number 27 and toggle the antanna tuner on and off on receive.There should be no change in received signal level (assuming the tuner is tuned up on the frequency)On my unit the level was dropping up to 30 dB I Replaced the relay which cured the problem.
Posted on Aug 31, 2008
Kenwood TS-2000 Power up fails
You will likely have to do a reset on the radio. The method to do this is hard to find in the manual. I have inserted it below. It usually works for me. Doing a full reset will reset EVERYTHING. It is essentially a last ditch attempt to get the radio going again. I hope this helps
PARTIAL RESET
Perform a Partial Reset if a key or control does not
function according to the instructions in this manual.
The following data is NOT erased by performing a
Partial Reset.
• Memory channel data
• Menu settings
• Antenna tuner preset data
• ANT 1/ANT 2 data.
Reset the transceiver by pressing [A/B]+ POWER
ON.
• "HELLO" appears on the display.
FULL RESET
Perform a Full Reset if you want to erase all the data
in all the memory channels. In addition, this function
resets all the settings that you customized, to the
factory defaults (i.e.- menu settings, antenna tuner
preset data, etc.).
Reset the transceiver by pressing [A=B]+ POWER
ON.
A confirmation message appears when performing
the Full Reset. Press the [A=B] key to proceed.
Otherwise, press any other key to cancel the Full
Reset and return to normal operation.
When you perform the full reset:
• All frequencies, modes, memory data and AT
preset data are set to the factory default values
(refer to "INITIAL SETTINGS", above).
Nov 24, 2016 | Kenwood TS-2000
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
Yeasu FT990 Gone Deaf
This could be many things but a good place to look is the TX/RX and ATTENUATOR relays. These are problem areas in a lot of radios. This is a complicated radio and if you need to ask this question I would suggest you find someone that knows how to work on these. It will require a fair bit of skill to find the problem and replace the parts. The radio has a lot of surface mount components which are difficult to work with without causing more, and often, expensive damage.
Mar 29, 2016 | Yaesu FT-990 DC Transceiver
How can I resolve the B1681 problem
the PATS tranceiver signal is the radio signal sent by your key to the Passive Anti Theft System. if you're setting that code, then either your PCM doesn't recognize the key you used to try to start your car, or your key has gone bad. it could also be the transceiver itself (sensor mounted around the ignition cylinderon the steering column) gone bad. good luck
Found in a posting by crazymechanmic.
Oct 18, 2015 | Computers & Internet
Voltage of the backlight on the Kenwood TS-60 Need to replace the backlight on the Kenwood TS-60 Transceiver radio. Need bulb voltage, type or number. Any specifics would be helpful
check voltage of existing wire leads....any 12 volt wheat lamp will do or use resistor with 6 volt....copper electronics carries 12 volt grain of wheat replacements for .49
Jan 25, 2010 | Radio Communications
Is there any software for a ts570 it is a ham tranceiver the software must work on microsoft vister computer
Shareware $39.95 18-May-2000 5,320K An Amateur Radio control program for the Kenwood TS-570 series of radios. It features the ability to read the memory channels to the program to be saved for backup purposes. The program controls most features of the radio right from your mouse. Want ...
Sep 06, 2009 | Computers & Internet
Urgently need aspare part for my Kenwood TS850 s/At HF Tranceiver
Watch ebay or QRZ.com for a used/non working unit that has a good display or maybe someone may part out a 850 on ebay.
Dec 30, 2017 | Kenwood Radio Communications
Computers & Internet Logo
3,309 people viewed this question
David Payne
David Payne
