Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV will turn on, but not respond
After watching a DVD, I hit the "Device" button on the remote to go back to regular TV watching. Nothing happened. I thought the batteries were dead, so I tried to use the "Device" button on the TV. Once again, nothing happened. Then I tried to adjust the volume and noticed that wasn't working. I have also tried unplugging it and that didn't do anything either. It seems to be locked. We can turn the TV on and watch a DVD, but that's all. We can't watch regular TV, can't play video games or even adjust the volume. (A bad storm went through the day before and the power went out. It took a while to turn on at first, but then it was fine.) Any help would be appreciated!!
  • 927 Answers
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Posted on Aug 05, 2008
How do turn my tv back to video mode so i can watch my dvd with a universal remote.
Check your universal remote for a TV-DVD or SOURCE or INPUT button and try that.
Dec 25, 2014 | Funai 24ME403V 24" 720p LED-LCD TV - 16:9...
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
Tv stuck on video
Sorry it took so long to respond to your request for help.You have to use the function button for the television, to leave the dvd function to the television. Just push the button that say's TV and you will return to the television mode of the remote control. I hope this information helps you with the problem of switch the functions on you remote control to use the television.Thank you for using FixYa and have a nice day!
Feb 17, 2009 | RCA 3-Device Universal Remote with...
Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Dec 10, 2008 | Logitech Harmony 880 LCD Remote Control
Emerson 20" flat panel tv/dvd
the problem is a bad inverter transformer replace the bad one and the set and dvd will work fine.
Mar 30, 2008 | Emerson EWL20D6 Television
RCA CTC203 No Colour in the Video IN or Svideo but colour is present on tv channels.
try removing your vcr and dvd connections first while watching TV programs alone!. if still there are no colors then your tv have a problem!
Dec 05, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
