Need help setting up second monitor for ny pc
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
You need a video card with 2 outputs for monitors. you can buy them at newegg.com. good luck
Posted on Jul 31, 2008
I have an LG E2350V monitor. When I connect to my desk top PC, it starts to display the pc starting up sequence, then after 20 seconds or so goes into Power Saving mode and it wont get out of it. ...
Hi keepintouch0,
Make sure that the power save settings are not set in the OSD of the monitor , and if they are set to switch off after some time , then you need to change the settings as per your requirement.
Hope this helps ...:) Let me know in case you have any queries.
Aug 01, 2011 | LG Computers & Internet
Video
this is the problem with monitor only sir.
please claim your warranty
Jul 28, 2008 | Samsung SyncMaster 920NW Monitor
Suddenly the monitor on the back of my Nikon D3000 does not light up, so i cannot change any settings, review photos etc. Is it possible I turned it off? How do I fix it?
Try pushing the two buttons that have a little green circle next to them at the same time for two seconds. This should reset all the basic settings on your camera. If this still doesn't work then you should contact your local Nikon authorized service center for repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon D3000 Digital Camera
I have a HP Pavilion a6430f PC and I'm trying to add a second monitor. After a software update my computer will not recognize the second monitor. Do I need to purchase an upgrade to my current NVIDIA...
go to control Panel and look in the Display settings, you should be able to see your video card in number one monitor as well as in number 2. I hope this helped. Good luck and have a pleasant day!!!
Jun 19, 2011 | HP Pavilion A6430F Desktop PC
When I first turn on the monitor I get a picture for about 1 second then it goes black. If I turn the monitor off then right back on I get the same 1 second pic then black. A different monitor works fine...
Make sure you are on the correct video setting on the monitor using the menu button.
If you are hooked up to dvi you need to make sure the monitor is on the dvi component. VGA same thing.
Hope this helps
Positive feeback always welcome
Mar 03, 2011 | Dell E198FP 19" LCD Monitor
Hello, 2 monitors running off d600 loptop one moniter not picking up windows wat is the problem help p'se
Hi. I hope this helps.
You need to open display properties, click on advanced, and make sure that the video adapter settings are configured to allow more than one monitor. some diplay adapters will only run on one monitor, some will allow cloning, where the same thign is displayed on both monitors, some allow span, which allows the total display to be split between the two monitors, and another setting to allow one to be the primary, and the second monitor for applications.
Also, check to make sure that on your power settings, you don't have it configured to power down monitors if not active. This can sometimes cause the second display to shut down when there is not an active signal going to it, and upon resumng it can cause the second display to not restart as it is supposed to.
Also, check each monitor seperately, having only one hooked up at a time, to ensure that the monitor isn't the problem. This is especially true if you are using flat screen monitors. They are notorious for working one minute, and the next they just quit. Almost all flat screen monitors..i.e. lcd, plasma, and dlp have capacitors that precharge to energize the screen, and those capacitors are quite prone for going out without warning.
I hope this helps you out.
Jan 23, 2011 | Dell Latitude D600 Notebook
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Anyone know how to set time on a NY-1385 watch?
First, go to the time mode which displays week day, seconds and timeas opposed to calendar, seconds and time. To do so, touch and hold upper left sensor until the watch beeps. Then use the upper right button to switch to the proper time mode. Then touch and hold lower right sensor. This will send the watch into settings mode.
May 03, 2010 | Watches
Second monitor - 'power save' mode.
Firstly, you can try to switch the second with the first monitor. Secondly, use only the second monitor as a main monitor and check that if there is still a problem or not. It might be because of BIOS. You can check and update BIOS with your computer manufacturer.
Feb 20, 2008 | LG L1918S-BN (Black) Monitor
Screen resolution
What is your monitor manufactoring year? Because old monitor could not set up to 1024x800 pixels. Please check the refresh rate also at the monitor property tab.
Dec 10, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
