Question about HP Pavilion F1703 17" LCD Monitor
How do you open the f1703?
I have read your solution by as a newbie I don't know how to open the monitor to access the circuitry. I'm affraid that doing improperly I could cause further damage
WITH POWER DISCONNECTED...
1. From the back, pullout the two rubbeer plugs visible towards the top of the stand. this will reveal two screws - remove them.
2. From the front. gently pull the front plastic bezel toward you from the bottom (where it says hp pavilion f103,the powerbutton and other buttons are). It should simply unclip along the bottom. Then work your way up the sides gently, finally when bottom and sides are free it should lift off the top.
3. Remove all the small screws around the side of the LCD display. The whole LCDdisplay, and electronicsbehind, should now be able to be lifte dout of the plastic chassis.
Posted on Oct 12, 2008
  • 37 Answers
If your affraid of causing further damage it might be best to leave it up to the repair man.
Posted on Aug 26, 2008
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
My monitor is cycling on for about 1 second and off for approx. 30 seconds?
tom lundin, If pc is known to be ok, then go here and do some reading: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ After you research problem then and only then come back here and rate this response on fixya as to it's merit. You should also do some reading in the FIXYA PROFILES of "budmrtn" "buddymc" "12fixlouie" and other CCFL lcd monitor techs for more info.
By for now. 12fixlouie
Oct 01, 2010 | HP Pavilion F1703 17" LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
Try to open a docoument file ,page came up but could not work on it for it said it locked
to open the document: click on the tab at the top of the browser that reads "Review" and there should be an option for unlocking the page / workbook.
Mar 19, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a hp pavilion F1703 monitor in which the screen goes blank after around 2-3 seconds. I turn the monitor off and then back on it does the same thing. Would anyone have an idea what it could...
It's your backlight adapter. You will have to open up the monitor to get to the backlight board and redo some soldering and maybe replace the four transistors. I just did a google search for the name of the monitor and there are plenty of posts out there to help. I had the same issue with my monitor. I redid about 15 or 20 solder joints and that fixed it. There transisters cost about $5 on ebay if the resoldering doesn't work. The problem is what is called cold solder joints. These are used in mass production circuitry, which is why so many electronics go out. These joints are a dull gray and hot solder joints are a shiny silver, these should be replaced, but just google the name of the monitor name and you should see plenty of others that had the same issues years ago.
Jul 15, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion f1703 screen goes suddenly black
After reading a number of posts regarding this problem, I disconnected the speaker from the screen electric outlet meant for this purpose, thinking it may have been pulling a bit too much amperage to the detriment of the screen. I am going to hook a small transformer to feed the speakers directly thereby bypassing the electric feed from the screen itself. Hope it continues to work. I will let you know if it doesn't.
Feb 19, 2009 | HP Pavilion F1703 17" LCD Monitor
LCD monitor
Normally TFT monitor backlights have a life of around 40,000hrs .Open up the monitor and check visually for bulged leaky capacitors.This monitor is reputed to fail due to dry solders on Inverter pcb.
Nov 24, 2007 | HP Pavilion F1703 17" LCD Monitor
Monitor flickered and then... smoke!
Hi Konsuma, You can open the monitor case and look to see what is damaged and order a new circuit board if needed. Check with www.lcdrepair.net parts and/or Repair.
Oct 09, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
182 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
