Question about GoVideo Go Video DVD/VCR Combo
I have a go video recorder/vcr the disk tray will not open any hints on how to open is says opening but dosenot open?
  • GoVideo Master
  • 17,130 Answers
It is sure that the processor is giving the commands and outputs the drive voltage to the loading motor to work and open the tray or load the cd.
This means that the motor is faulty, the motor drive output IC is defective, the circuit leading to the drive IC must be checked for the loading voltage from the processor to confirm.
Finally the possibility of the motor being jammed, the mechanism or the gear movements are restricted by foreign particles or that there is misalignment of the linkages of the loading mechanism.
This means there is voltage on the motor without the mechanism moving which will require an overhauling of the drive mechanism.
Remove the section, check voltage and reset.
Posted on Mar 10, 2011
SOURCE:
DVD Tray Will Not Come Out
Download updated software for free on Panasonic Website then take a Paper Clip or other small object and insert it in the small hole in front of the machine and manually open the Disk tray. The Updates should take care of the Problem !
Oct 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Menu bottons will not work flashing open disk tray
I have one that does that but I can still use the VCR for manual (not timed) recoding.
Get used to using VCR again.
It also serves as an AV1 to RF converter on dish units to RF TV's.
Apr 05, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Shows Open when closed and vice versa. Tries to
The tray orientation may have gotten messed up. Try opening the player and then unplugging it, closing the tray with the unit powered off and then turning it back on.
Jan 06, 2010 | RCA DRC8295N DVD Recorder/VCR
The DVD door does not open and there is no DVD in the holder.
To get the tray out for inspection try straightening a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Jan 01, 2010 | Lite On LVC-9016G DVD Recorder/VCR
The DVD drawer won't open and close on our Go Video VR3845 combo. Help.
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Dec 31, 2009 | GoVideo VR3845 DVD Recorder/VCR
Samsung DVD-VR330: Disk Tray won't open
The solution is to unplug the machine and wait 10 secs. and plug it in again. I have to do this often. another part of the problem may be that some of the blank disks are bad. I got the DVD+R at Staples and about 4 out of 10 were able to be formatted. I am about to try the DVD-RWs.
Feb 01, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Dvd tray won't open
Don't take the cover off. Open the door and use a small flat instrument to depress the tray release buttom (it is indented on the lower right hand side of the tray. If there is a disk remove it. Turn off your system and the tray will close. Restart you system and see will the trat open.
Jul 15, 2008 | Lite On LVC-9016G DVD Recorder/VCR
RCA DRC83200N DVD Recorder tray won't stay closed
hit the top of the player hard. really, it works.
Dec 15, 2007 | RCA DRC8300N DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
26 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
