Sharp 25R-S100 25" TV Logo
Anonymous Posted on Jul 31, 2008
Tv cannot display only a line in the screen
My tv screen shows only a white line in middle and automatically off ,help me sir?.no sound no display.automatically off when tv is on.
  • Anonymous Aug 01, 2008
    the solution is only replacing the ic relate to colour
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
141
Points
Check the vertical deflection circuit maybe there's a bad capacitor. If all the capacitors are good replace the vertical deflection ic.. the automatic shut off is caused by the white line at the center.. its normal to protect the picture tube.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1259
Points
11
For short circuit it will show  like this if no short circuit
i think ur tv display tube has dead if it is in warenty pls exchange the tv
My Dell XPS 9530 has a white vertical line on the display
Fixing this old of a TV would be a waste of money as unless you have the testing gear and expertise you would be guessing. Just buy new and be happy. You could also join a book club and give up watching TV altogether. LOL
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
My asus laptop display is showing a blue or purple haze bar through the middle.
sounds like you are right there do it before the warranty runs out!
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
1helpful
3answers
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Black display with a horizontal white line in the middle.
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to http://www.nesda.com/locator/state_search.php and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Bill
Nopicture
No vertical deflection. Vertical output IC, caps.
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
No Video
is the white line in the middle of the screen going left to right, if thats the case then sounds like a frame collapse, get it checked by an engineer
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
