Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
"clean" light my ionic breeze has been cleaned and as soon as I turn the device on the cleaning overdue red indicator light turns on and remains on. It is no longer working, cleaning the air, or collecting particles...is there a solution? Or is the device just broken? Not even a year old yet Red clean light stays on even after cleaning.
  • 2 more comments
  • mariasu Jul 31, 2008
    I cleaned my ionic breeze, followed the instructions to a T but now the "clean" light stays on and it has stopped working - the machine thinks it needs a cleaning when it doesnt. Can this be fixed?
  • Anonymous Jan 05, 2009
    I have the same problem. Bought at Walmart and kept the box and receipt for about 6 months. About 3 or 4 months after I got rid of the box, the "clean" red light came on and has been stuck on. No matter what I do to clean it, reset it, wipe the blades, etc. the light remains on!!!
  • Anonymous Mar 14, 2009
    thanks for the advice - however, it didn't work for me - annoying red light is still on - should I just cut my losses and through this out?
  • mdcitrus May 06, 2009
    My quadra is arcing at the top of the unit. Sparkling clean blades, clean wires etc. Unit turns on, arcs for 20-30 seconds and turns itself off. There is nothing I can see between the metal blades and rubber dividers that I can see. Blew them out, used a bit of stiff paper like dental floss... nothing. Unit is about 2 years old.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Posted on Mar 14, 2009
  • 2,794 Answers
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Posted on Jul 31, 2008
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing again. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Posted on Aug 10, 2009
    New Friend:
Just wanted to say thank you to the one that said clean the bottom of the blade part with qutip's and alcohol and tip it upside-down and tap on the bottom to get out any particuls that could be trapped. Remember to put it on its side to put the blades back in and press in firmly. Worked for me still working.
Posted on Dec 31, 2016
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze quadra constantly blinking cleaning overdue, evenghough it is clean.
If it still works after you cleaned it, consider yourself lucky. If light blinking bothers you, just put a piece of black electrical tape over it and enjoy it. That unit has been driving me nuts for years. I cleaned mine and now it doesn't work at all. A blinking light I could put up with, with a little tape. Enjoy it because it still works.
Apr 05, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Red Cleaning Light is On
I have the same problem. I totally took the unit apart and cleaned it out. After I reasembled it, the same thing. Just that little cleaning overdue light on. I can tell that it is not working as well as there is no breeze coming from the front. That is what I get for buying a serviced unit.
Nov 25, 2007 | Sharper Image Professional Plus Ionic...
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
2,821 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
