Question about Magellan RoadMate 700 GPS Receiver
No sound Hi Dan, My unit has zero sound now. It had "scratchy sound" like an old cracked speaker for awhile. Do they make replacement speakers? I did pull the housing apart and looked at the speaker, but did not see any obvious cracks or holes. It works fine except for the sound. Thanks for the help
Try to reinstall the firmware....
Posted on Sep 17, 2008
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
My one speaker sounds scratchy and doesn't have as good sound quality as it did when I first bought the system about a year ago. there is a 2 year warranty, will Logitech replace the speaker?
Hi, Thanks for using fixya.
Logitech Is a very good company and I am sure they would.
1-800-231-7717. Monday - Friday, 6:00am - 6:00pm PST ...
Terry
Feb 17, 2011 | Logitech Z-2300 Computer Speakers
No sound on my Dell Dimension 3000
i would try checking the plug for your speakers to see if it is loose.
If you move the plug is there any static that comes from the speakers?
If you have headphones maybe try plugging them in to see if you have sound through them.
If you do have sound then i would say it is your speakers that are bad.
If you get no sound or scratchy sound through the headphones, then i would suspect either a loose jack connection for your audio or a dying audio chip.
Feb 14, 2010 | Dell Dimension 3000 PC Desktop
The speakers are making a very scratchy noise. They are hooked up to my desktop computer. When first purchased last year, they sounded quite good. Now, they are very scratchy and not on high volume.
Do you by any chance have any other wireless device like a cell phone near the speakers when you hear this?
Any kind of device that has a magnet field will cause scratching sounds on the speakers. I discovered this quite by accident with my old Boost mobile phone.
Debbie Mahler
MICE Training, Technology & Education
mice.org
Oct 24, 2009 | Bose Companion 2 Series II Multimedia...
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Soundspace 5 Right Channel Problem
Some thing has broken in the unit! Switch speakers around to make sure its not a blown speaker! If its not the speaker then your right channel control will need replaced!
please rate answer!
Jan 24, 2009 | Nakamichi SoundSpace 5 Shelf System
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
Sound and picture problem
MAY BE THERE IS LEAKY CAPACITOR IN AUDIO SECTION OF YOUR TV OR A RESISTOR THAT CHANGE THE RESISTANCE. OR LOOK FOR A CRACK SOLDER IN THAT AREA AND RESOLDER IT.
Jun 07, 2007 | Toshiba CF32G40 32" TV
Harmon Speaker distortion
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
Dec 02, 2006 | Harman Kardon Harmon Kardon SoundStick II...
Magellan RoadMate 700 GPS Receiver Logo
119 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
