Question about Adapters.com Video to Monitor HD-15 Converter, Watch any Video Source on your Computer Monitor (XVIEW1)
Internal HD cabling
Ginko; If you're talking about my Desktop external HD, it comes with a USB cable and is connected to the rear of my PC.
If you're talking about the internal drive (my primary problem) your reply makes no sense.
  • 19,396 Answers
I understood your problem there are two different connectors
SATA:
And PATA:
If your computer has IDE (PATA) connectors you need an adapter like this one:
Native SATA Drive to IDE 40-pin Adapter for Most Enclosures
Posted on Jul 31, 2008
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My hard drive keeps disconnecting and then reconnecting angain.
if the drive is internal, then it's time for replace. it will disc/rec when overheating.
if the drive is external and powered by usb port (or usb hub) check if the port has enough power. and if the cable to HD is a Y cable (one side to hd and two to usb ports, one for data, one for power). and dont connect two peripherals that need power from usb on same pc, like a hd and a dvd, they will rob energy one from another, both mailfunctionating.
Apr 14, 2010 | Computers & Internet
I don`t connect with usb of PC. The USB port not reconigze it
use only the rear USB port of desktop, because by using any extension or hub there is a voltage drop so that why it is not recognisezed, only use the rear USB port and use the orignal cable or branded product USB cable, loose cable also dont work with it.
Feb 14, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
My light is on and a buzz sound is heardwhich stops after a minute and no data is displayed
You do not say whether the HDD ever worked.
If it did, and stopped, chances are that the internal HD is damaged, or the motor performances degraded and it now requiring a higher current than the USB port can deliver.
Try plugging it on a different USB port or, better yet, into an externally powered USB hub. There are also special cables which plug two USB ports into one and deliver double current to the appliance.
As a last resort, it might be possible to recover it by extracting it from its enclosure and connecting to a desktop PC via a 3.5-to-2.5 inch HD adapter.
In all cases, unless it never worked on that PC (which means that the problem might be in that PC's USB port), I'd strongly suggest to back up all data on another disk.
Oct 26, 2009 | Seagate Free Agent Go Small 12 GB USB...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Wireless adapter
Go for an external USB wireless adapter, and the speed may vary depending on barriers and the distance from the router, the max. distance is about 30 ft from the router.
Tell me if anything else you want to know abt the wireless connection?
Askari :)
Mar 28, 2009 | Dell Dimension 8400 PC Desktop
Televison & Video Logo
60 people viewed this question
Top Adapters.com Televison & Video Experts
Electro Med Services...
Are you an Adapters.com Televison and Video Expert? Answer questions, earn points and help others
