The f10 system restore button doesn't work when you press it the system just bypasse's it
    Genius:
  • 1,550 Answers
You try entering safe mode?
Posted on Jul 31, 2008
The F10 restore function is set in the MBR of a hard drive. To set the MBR command a free program from terabyteunlimited can be downloaded from the following link:
http://www.terabyteunlimited.com/downloads/wp/mbrsetupv2.zip
Once the computer is booted with the floppy created with the previous download, the following command should restore the F10 function:
mbr 0 /install sel 5 10 "Press F10 for the recovery partition"The command assumes you are working on hard drive '0'. The '5' indicates the time in seconds to display the msg and the '10' indicates the function key to use. The restore partition should be the first partition on the hard drive and it should be hidden.
Good Luck
Posted on Apr 02, 2010
Alt + F10 combination doesn't work
and it will if win xp is the only operating system installed
the defaults come after the os is up and running and all of the default settings can be changed in the control panel defaults
Dec 21, 2017 | Acer Ferrari 4000 Laptop Notebook
Hp compaq laptop how to restore to factory default?
Go to Start/All Programs/HP Tools/HP PC System Recovery
If this doesn't work then try pressing the F10 key multiple times during the bootup to access the recovery console.
If this still doesn't get things fixed then you need to re-install XP
If this answer helped you then do visit my blog TECHAMY
Jul 09, 2012 | HP Computers & Internet
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
I need help on restoring my compaq armada e500
Hi Welcome to FixYa!
You could try these steps on restoring your laptop into its factory defaults.
1)Turn off your computer if it is on. Wait for the system to shut down completely. Once it is off, press the "Power" button to turn it back on. Press the "F10" button at the top of the keyboard repeatedly as soon as you see the screen turn on. This will let you enter the setup menu.
2)Use the arrow keys to move between the various menu tabs at the top of the screen. Press the "Right" button until the "File" tab is highlighted, then press the "Enter" button to enter this menu. Here you can make changes to the settings of your computer, or in this instance, restore factory default settings.
3)Use the "Up" and "Down" arrow buttons to move to the "Restore Defaults" option, then press enter. You will see a screen asking "Are You Sure You Wish to Restore System Defaults?" Press the "Y" button to continue. The system will begin restoring your default settings. Do not press a button until a screen says "System Defaults Restored."
4)Use the arrow keys to move down to the "Save Changes and Exit" option and press "Enter." The system will save your changes and automatically reboot your computer. You do not need to press "F10" this time as the computer will start Windows normally. You will see the factory settings have been restored once the system loads.
Hope this could help!
  • Jul 07, 2011 | Compaq Armada E500 Notebook
    I recently reboot my dell and after that my laptop doesn't open but its till open the power but my monitor is all black screen..and it has an icon keep on blink and i think it looks like a...
    Hello.
    Either you have an operating system problem or memory issue.
    First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
    If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
    If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
    If still not resolved, you'll probably need to reinstall your operating system.
    Hope this helps.
    Jun 30, 2011 | Computers & Internet
    System restore
    if your computer has a system restore capability you might be able to restore it to a date when you had these phone no. on your computer (this may vary depending on your operating system)
    click start all programs accessories scroll to system tools open you should see a system restore
    open this up click next then select a previous date to restore your computer to
    also you might try one of these
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    or
    During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
    Also you might try
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
    May 28, 2011 | E-Machines Computers & Internet
    TRYS TO BOOT REPEATEDLY, BUT WILL NOT BOOT.
    When booting up, press the Delete key repeatedly, then select Default Settings in the BIOS, then press the F10 key to save and restart. If that doesn't work, try to get into Safe Mode and do a system restore to when the computer would boot properly.
    To get into safe mode, press the F8 key repeatedly on bootup, then select Safe Mode. Once you get the to desktop, a box should appear, press No and it will open up System Restore. Choose a date from the calendar of when the system was working, and restore to that point. System Restore does take around 20+ minutes to complete, so let it run and be patient.
    May 08, 2011 | Toshiba Satellite A45-S150 Notebook
    How to reset my motherboard - dg35ec intel
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
    click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
    Hope this helps
    Apr 26, 2011 | Intel DG35EC Motherboard
    Reset acer laptop to factory settings
    During the system bios boot press and hold ALT + F10, that should start you into the system recovery options.
    Oct 30, 2009 | Acer TravelMate 2300 Notebook
    How to restore my acer aspire 5315 back to factory settings i have tried every thing i can think i press f8 on startup then boot logging but nothing happens HELP?
    Just after pressing Power button try to press and hold FN+F10 if this does not work try FN+F11, you can also keep holding a FN and simultanuously pressing F10 or F11. This should take you to the system recovery screen then follow procedures from the screen. Another way is to activate hidden system restore partition on the hard drive if there is any, the simply reboot your computer.
    Jul 20, 2009 | Acer Aspire 5315 Notebook
    Computers & Internet Logo
    1,166 people viewed this question
    David Payne
    David Payne
