Question about Kodak Easyshare Printer G600 Thermo Printer
Kodak Easyshare G600 printer dock problem!
Upon removing the old 'ink cartridge' after it was empty, as always, I tried to reinstall a new one to no avail. It appears the piece that comes down when printing a picture is stuck in the down position and will not allow a new cartridge to be inserted! Help please!!!!!!!!!!!!! Thanks
Brenda
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Posted on Nov 27, 2008
Ink cartridge stuck printer
The manual says: To remove the cartridge, push up on the Cartridge-release tab then pull out the cartridge. It looks like a green lever to me, you have to push.
Nov 27, 2013 | Kodak Easyshare G600 (1633379) Dock /...
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
May 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Can not remove ink cartridge in Kodak EasyShare Printer Dock
Turn the power off. Hold down the transfer button, on the left side, and at the same time hold down the left arrow button, on the right side. Holding both buttons, turn power on. You should hear it recycle. After it stops, push in the cartridge in until it locks. Then you should be able to release the catch and remove the cartridge. I had the same problem, found this on the web and it worked for me. Hope it does for you, too.
May 18, 2009 | Kodak Easyshare Printer G600 Thermo...
Ink cartridge is empty and I can not remove it to change it. It won't come out!
Press the power button to turn off the printer. Hold down the transfer and left arrow button at the same time. While holding them down at the same time turn on the power button. Let it go through the initialization process and once completed, the head should be in the up position. Open the cartridge door and push the cartridge to make sure it is latched and locked in place. Once the cartridge is latched, release the latch and the cartridge should release itself. Remove the cartridge from the printer.
May 18, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Can't remove used ink cartridge from G600 Printer dock???
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Mar 20, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak Easyshare Printer G600 Thermo Printer Logo
557 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
