Question about Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and not working
OK. I've got a problem. I get the f21 and 5d error. I've checked the drain and cleared it out. But the machine keeps reverting back to f21 and 5d. What can I do?
  • Anonymous Mar 19, 2014
    Wont drain. Filter is clear
    Master:
  • 382 Answers
Check the pump cean out on the frount of the pump unscrew the plug, be prepaired for some water and also unplug the washer before starting...
The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground.!!..Thank you..
Please Post back how things turned or for further assistance..
Kind Regards!!!...
Posted on Jul 31, 2008
    Genius:
  • 3,422 Answers
remove the bottom panel 3 scres and you will see it check the filter there for a blockage
  • Priya darshan Jul 31, 2008
    F21 is:
    LONG DRAIN
    If the drain time
    exceeds 8 minutes the water valves turn off.
    NOTES:
    After 4 minutes the
    “Sd” error will be displayed, then
    4 minutes later the
    “F/21” error code will be displayed.
    Press PAUSE/CANCEL
    two times to clear the display.
    Possible
    Causes/Procedure
    1. Check the drain
    hose and make sure it is not plugged or
    kinked.
    2. Unplug washer or
    disconnect power.
    3. Check the
    electrical connections at the pump and make sure
    the pump is running.
    4. Check the drain
    pump filter for foreign objects.
    5. Plug in washer or
    reconnect power.
    6. If the above does
    not correct the problem, go to step 7.
    7. Unplug washer or
    disconnect power.
    8. Replace the pump.
Drum won't spin on Tricity Bendix AW 1260W washing machine. What do I replace? Is it worth it? Machine is 7 years old.
Hi just food for thought,I normaly fix my things that are brocken,but I was told by a washing machine teck that the life span is usuely 5years,some times you get lucky and other times it gose wrong and you keep throughing money down the drain,I wish you the best and hope it works out for you if you deside to try and fix it.
Nov 21, 2016 | Tricity Bendix Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles. I've tried a 'service wash' @ 95deg to clean the machine. I've also checked the detergent/conditioner...
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 02, 2011 | Hotpoint Washing Machines
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
227 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
