Question about NEC Dterm DTP 16D-1 Corded Phone
LCD display backlighting
I have the Dterm 80 phone at work. Some people in my office have their LCD displays backlit with a soft green glow. Others don't. My phone sits in dark corner and I'd like to activate this feature, but can find no mention of it in the manuals. Does anyone have any advice for turning on the backlight? Thanks.
  • 1 more comment
  • pdxalex Aug 13, 2008
    I can use those arrow buttons to control the darkness of the LCD letters, but they don't seem to affect the backlighting of the display.
  • blz131356 Dec 31, 2008
    tried changing up/down arrows when a call is coming in and when no one is on the phone all it changes is the lcd contrast not the back lit at all?
  • Adaly May 11, 2010
    Does anyone know who might be providing maintenance (on contract basis) for NEC Dterm 80 ELIte IPK II system in Toronto? Our current maintenance provider charges too much...
    and we have not had any siginificant problems with the system in the past.
    Thank you.
  • 3 Answers
If there are up and down arrows on the phone you should be able to press them when the phone is not picked up to change the LCD.
Posted on Aug 06, 2008
How to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
Nov 01, 2012 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well.
Mar 14, 2011 | Uniden BC340CRS Base Scanner
Backlite not working.Have replaced inverter.still no backlite.Screen is visable with flashlite. pror to losing ccfl It would come on for 1second,by flicking lid closure switch. that then changed to a...
HI chuck_whir
Have tried to change the LCD display?
problems you may have 2. If no LCD display, chipset the display may have a problem.
CHANGE your LCD screen first. If the problem still the same, this means that the chip display is a problem.
(The symptoms occur, redness or green screen, vibrating screen, stuck, there is a red line or lines that vibrate at the bottom, it requires you to make a more detailed processes such as reflow or better reballing)
thanks and regards
Dec 21, 2010 | Acer Aspire 5610-4648 Notebook
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
Setting a message on my Dterm80 phone
You have to dial a feature access code to record and play back messages on a circuit card. Press the volume button up or down while the handset is in the cradle. This should fix the LCD.
Mar 25, 2010 | NEC Dterm DTP 16D-1 Corded Phone
We need a cordless phone that can be used with our NEC Dterm 80 s
Thank - you but I have found a company from whom I can buy a NEC cordless phone. Have a good day.
Oct 05, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
You will need a professional installer to do this for you.
Cross conecting and proper grounding required for any installations.
Mar 18, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80 LCD display is defective, where do I get parts? How difficult is it to change?
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Dec 08, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
should see the normal display then.
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
622 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
