Question about Sony DAV-IS10 System
Sony DAV-IS10 Error Code C 13 71
I've put a brand new CD in to play and the machine has come up with this code. It will not eject the CD, just comes up with No Disc. Any ideas on what the error code is and what to do?
  • joaofeio Sep 11, 2008
    I have the same problem. Can anyone help me.
    Thanks
I had the same problem, took my system to the service centre - they replaced the lens and it works fine now. They charged me Rs 1000 (About 25 USD)
Posted on Feb 16, 2009
2 Suggested Answers
SOURCE: C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Posted on Oct 07, 2008
CD player doesn't work
try another disc make sure it's a cd from a retailer. sometime home made disc don't play on older cd players because of formats. as for eject problems you might find you have to send it back to the retailer for repair
Apr 16, 2014 | Arcam Solo Music System Cd Amp Tuner...
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Sub q error
I think that is a wise choice, this is clearly a manufacture defect.
Apr 01, 2012 | Marantz Audio Players & Recorders
Turntable will power up, all the lights come on,reads the cd but does not play. unit has to be turned off then on to eject the disc ? (hope this helps) Any ideas?
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
Jun 24, 2011 | Pioneer CDJ-1000 CD Player
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
6-cd changer says error 3 and won't eject CDs
hi i recently bought a lexus ls400 and it the trunk it has a ten disc cd changer by the steering wheel in the car is this little black box that keeps reading E-99 evertime i press play on this odd little box that is the control device to make the cd's play i've put the cd 's in the changer upside down right side up testing it and still the little black cd player play button/disc change button keeps saying E-99 my question is, is it a fuse or is this cd player thing near the stearing wheel just a peiece of garbage please contact me at phantizzle123@yahoo.com if you have any idea why this is doing this because i can't play any cd's theres no cd player where the cd/tape decks usually are in cars in the middle above the column shift. it would mean the world to me if you could help me out with any information as to why this brand new sony ten disc cd changer is giving issues to the cd player thing next to the stearing wheel on the right it's kind of hidden but it just won't stop saying e-99 no matter how brand new a cd i put in the changer thank you your friend john bunce
Aug 14, 2009 | Car Audio & Video
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
CD "disc error" in Jeep Grand Cherokee
BE SURE THE CD THAT CAUSED THE PROB DIDNT HAVE ANY TYPE OF STICK ON LABEL THAT MAY OF COME OFF INSIDE, ALSO IVE SEEN CHILDREN PUT COINS IN THE CD SLOT IF YOU HAVE CHILDREN. MAY WANT TO TRY A CD LENS CLEANING DISK PROB FIND AT RADIO SHACK OR BEST BUY TYPE STORE.
Oct 01, 2008 | 2005 Jeep Grand Cherokee
Ejects CD'd rather than playing them
You probably have problem with central sensor on CD mehanism,it may be dirty,its doesn't give information when changing discs and unit "things" that you press OPEN.It can be very tricky do fix because you have to dissembly whole CD mehanizam and if you are not good in it its better to find a good service
May 03, 2007 | Nakamichi SoundSpace 5 Shelf System
Sony DAV-IS10 System Logo
1,474 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
