Question about HP Office Equipment & Supplies
Would like to have a owners manual so I know how to work my new printer. i.e. how to use the duplexer, how to use legal paper, etc.
  • Anonymous Nov 28, 2008
    Need installation instruction for a C8955A Duplexer on a 7960 Printer.
    I can physically install the unit, but am told that the Duplexer has not been installed.
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
How do i remove the paper from the duplex unit when there is no paper there
You could have a broken actuator or the spring came of. I would check all areas for paper not only the duplex area. I've seen paper jams in other areas show a different indication on the display.
Sep 21, 2014 | RICOH - PRINTERS Ricoh Aficio Sp C430dn -...
Each time I try to use legal paper in my printer (I have a duplexer), I get a paper jam. What do I need to do to fix it? This is very frustrating as I desperately need both legal and regular paper...
I believe that the "printer" you have is actually a copier. Hold on, let me get it straight... duplex means 2 in some kinda language. I'm not sure I got the actual answer right cuz....I'M A KID!!!!
May 12, 2012 | Ricoh Aficio SP 4100N Laser Printer
Can the Brother DCP 7020 all in one printer print legal size paper?
Yes it can
  • Large paper capacity. Features a 250-sheet paper tray adjustable for letter or legal size paper. Plus, a single-sheet manual bypass for envelopes, labels or other types of media.
For your convenience Here is a link to the owners manual. Page 23 shows how to adjust the paper drawer to fit legal paper
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Jul 06, 2011 | Brother DCP-7020 All-In-One Laser Printer
Im trying to make legal size copies
Check your owners manual to see what the acceptable paper sizes are. Legal paper is 8.5"x14". If legal paper is listed in the acceptable paper sizes there should be a tray to handfeed this size paper. Look for the term "single sheet manual bypass" in the owners manual. I beleive this tray or slot is on the left hand side of the printer.
Dec 06, 2010 | Brother MFC-7340 All-In-One Laser Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here :
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My manual was in a strange language. How do I
Your manual can be found here.
Printing on both sides of paper You can print on both sides of a paper; duplex. Before printing, decide how you want your document oriented. You can only use this feature with Letter, Legal, A4, US Folio, or Oficio sized paper.
Do not print on both sides of the special media, such as labels, envelopes, or thick paper to print on both sides of paper. It may cause a paper jam or damage the machine.
  1. To change the print settings from your software application, access Printing Preferences. (See Opening Printing Preferences.)
  2. Click the Layout tab.
  3. From the Double-sided Printing section, select the binding option you want.
    • Printer Default: If you select this option, this feature is determined by the setting you’ve made on the control panel of the machine.
    • None
    • Long Edge: This option is the conventional layout used in bookbinding.
    • Short Edge: This option is the conventional layout used in calendars.
    • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing.
  4. Click the Paper tab, select the Paper Options.
  5. Click OK or Print until you exit the Print window.
If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that , a message appears on your computer. Follow the on-screen instructions to complete the printing job.
Good Luck!
Jan 06, 2010 | Samsung ML-2855ND Laser Printer
I just bought a new Dell with Windows 7. Installed the updated driver from brother. Printer worked OK. As a page was feeding back into the machine it got stuck. I removed the page. But since then the paper...
This could mean that the printer is expecting paper of a particular size (for duplex printing). Press the job cancel button and check that the paper size is set for the correct paper type (A4, Letter or Legal). That light will also blink if the back cover is open or the duplex tray is not installed.
Dec 11, 2009 | Brother HL 5250DN Laser Printer
Prints off the paper
Check the settings on the printer itself. It may be set to legal and this might override the properties settings. It probably is not printing duplex because it is waiting for the other 3 inches of legal.
Aug 03, 2009 | HP Photosmart C7280 Printer
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
16 people viewed this question
Ben Johnson
