Question about Sony DSR-11 DV / Mini DV VCR
When I try to play PAL tapes, there is no picture
I have a bakers dozen Mini-DV tapes that were supposedly recorded in PAL.  I am trying to watch them, and there is no picture, just a blank screen.  The deck is able to playback other tapes that were recorded in PAL, so I don't know what the problem is.
For some reason, when I push play, it says NTSC (even though it's switched to PAL).  But when I flip the switch to NTSC, it says PAL on the screen.  I'm stumped.  Does anyone have an explanation or a solution? Tapes don't play on a canon camera either.
  • 1 more comment
  • sswiller Jul 31, 2008
    But I have other tapes, which were shot in PAL, and they will play fine on the DSR-11 (both the analog signal and the firewire).
    I can't get any image signal at all, neither analog nor digital.
    The moniter is a Sony Trinitron. I know that the problem is not with the AV cable because other tapes work fine.
  • Sony Master
  • 2,794 Answers
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Posted on Jul 31, 2008
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jul 31, 2008
    You can play them on a firewire connection. Thats a different signal. The analog signal is probably NTSC by default. PAL signal are only used on European a/v equipment.
  • Tim Babcock
    What kind of monitor are you using?
  • Tim Babcock
    It could be av cable you are using. It might have a short in it.
  • Tim Babcock
    The only other suggestion I have it to clean the heads on the take with a DV tape cleaner.
    That might make a difference.
Picture during playback is badly distorted
There could be several reasons for badly distorted pictures. considering the age of the unit as DV camcoder which I am guessing would be quite a bit. Most likely the heads have worn out and need replacement. I am assuming you have this problem with newly recorded tapes being played on a TV directly from the camcorder. For this you may also need to check if you are using new tapes and whether the recording mode is PAL or NTSC as per the TV format.
Alternate test would be to play back a previously recorded tape back from the camcorder. That way at least you can establish if the problem is the read head or the write head or the tape itself.
Aug 16, 2014 | Canon Elura 100 Mini DV Digital Camcorder
No signal, only blue lcd-monitor, when playing my footage, yesterday it was ok. also trouble with recording
Did you try resetting the camera by turning it off, taking out the battery and removing any other source of power? Try this first to hard reset the camera.
Does the optical viewfinder function or is it also blue?
Hopefully hard resetting will solve your problem but if not then there may be an electronics fault in your camera.
Jun 24, 2008 | Sony Handycam DCR-TRV900E Mini DV Digital...
Does this cam, play the mini dv tapes????
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
Jun 24, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
No picture when playing the tape back
Clean the drum assumbly with a head cleaning cassette and try
Mar 16, 2008 | Canon ZR80 Mini DV Digital Camcorder
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
Cannot watch anything
Just head cleaning cassette and play ones
Feb 10, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony DSR-11 DV / Mini DV VCR Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
