Question about Whirlpool Kitchen Ranges
The lower element of the oven is open circuit the part no: is LR 66863 csa C 75856 On the aluminum tag it is written 11 BO 21197 001 250 V 2500 Watts
  • 5,911 Answers
Okay...you need to replace the element. The following link gives you step-by-step instructions on how to perform this repair;
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
The lower element if your BAKE element. You can find replacement parts on line at searspartsdirect.com. Just type in your model number (located on a nameplate around the oven door opening or lower drawer opening) and look under the various headings on the next page. Another great site that offers competitive pricing is repairclinic.com. Sometimes their parts are cheaper. Use the Sears website for correct part identification as they have excellent component locater drawings to assist you. Once you get a price, however, compare to see if you can save.
I hope this helps you.
Posted on Jul 31, 2008
I have a neff B6774N0GB combi oven. Activated the hot air button and it has tripped the circuit breaker. Fan element examined and looks perfect. Oven is isolated from other appliances
The hot air function uses a great deal more current than the other functions. Check the tag on the oven for current requirements, and check the rating of the circuit breaker in use. If the breaker is rated lower than the ovens rated maximum current draw, it will trip under the load. If the rating of the breaker is above the ovens maximum current draw, and there is nothing else plugged into that circuit, the breaker may need replacement.
Sep 14, 2016 | Neff Microwave Ovens
Single element stove oven, doesn't get hot enough
Your oven probably has a feature called a hidden bake element. The element is located beneath the floor of the oven. (Because of this, NEVER put aluminum foil on the bottom of the oven because it will get hot enough to melt the aluminum foil and make it bond to the bottom of your oven.) You can adjust the temperature of your oven through the electronic oven controls. Check your owner's manual for how to do this.
Oct 08, 2014 | Kenmore Kitchen Ranges
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Sep 12, 2009 | GE JTP45 Electric Double Oven
Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Mar 20, 2009 | Ovens
MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
1,561 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
