Question about Sharp Office Equipment & Supplies
POLYGON MOTOR DEFECTIVE - SHARP JX-9500 printer, do you have a solution? Thanks
  • GEOLAN Aug 01, 2008
    Bubbabear64 thanks for your reply. This is something I was looking to fix myself, to request a call out would cost arms and legs and would not be cost effective as the printer is now some 10 years old. If you could help further i would be grateful.
    How
    Thanks
    Geolan
  • Tim Babcock
    Tim Babcock May 11, 2010
    I've been told by another blog, this is the part number you are looking for:
    RMOTN0020GCZZ
    Is this something you want to fix on your own or do you want to find someone in your area to fix it for you?
  • Sharp Master
  • 2,794 Answers
Theres a company I do business with that sells Sharp parts called Precision Roller. There located in Arizona. The phone number is 800-323-9523.
Manualuniverse.com might have the service you are looking for.
Posted on Aug 01, 2008
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
What does error code L6-10 mean on a Sharp AR-235 copier? Would it be worth fixing? Thanks
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 24, 2010 | Sharp AR-235 Copier
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
rotate normally.
Cause The LSU connector or harness in the LSU is
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Jul 01, 2009 | Sharp AR 163 Copier
Sharp ar-m208 message
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Sep 23, 2008 | Sharp AR-M208 All-In-One Laser Printer
63 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
