Cars & Trucks Logo
Posted on Mar 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This morning tried to start my 03 sierra 1500, i opened the driver door cab lights came on, put key into the ignition turned the key and the lights went out and the truck would not even crank nothing. Tried turning the key again an nothing the truck would not crank no lights would come on inside cab or outside the truck. Could you tell me were to start trying to fix the problem? Thanks
Anonymous
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • GMC Master 1,949 Answers
  • Posted on Mar 10, 2011
Anonymous
GMC Master
Level 3:
Renaissance:
Answers
1949
Questions
Helped
402766
Points
5880
Test and replace battery
Anonymous
Level 3:
  • Master 3,400 Answers
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
985120
Points
10767
Try jump starting it. I suspect your battery is dead. After time they don't hold a charge as deep as they once did. Have it load tested to verify. Your lights and other options don't draw nearly what your starter needs.
My2002 sierra with a4.8 with a good battery, all my dash lights and cd player come on but the truck doesnt turn over right away sometimes it takes 5-10 minutes 2 start of repetitively turning key over
battrey is good but truck makes no sound and wont even click
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusbattrey is good but truck makes no sound and wont even click ... Asked by Jennifer May 15, 2013 at 03:21 PM about the 2002 ... quite obviously the amps aren't getting through~ how do you know the battery is "good". the date ... If it turns over your power and starter are good but the ignition circuit ... Used GMC Sierra 1500".Missing: a4
Intermittant Failure to Start : Chevrolet Silverado 1500 ...
repairpal.com > Problems > Chevrolet > Silverado 1500
first start engine turns over alot. 2000 Chevrolet Silverado 1500. Hard start. When starting my truck it often takes two or three attempts. It kicks over but does not ...Missing: a4
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at ...
forums.edmunds.com > Chevrolet > Chevrolet Silverado 1500
Oct 20, 2008 - 30 posts - ‎19 authors
i got a 2001 silverado 1500 and it wont start it turns over and fires and .... Put the key in and the truck barely starts due to the battery being weak. .... If it was really 8, the lights would be dim? .... I have a 2002 GMC Sierra 4.3L 2WD. ... I bled the fuel filter looking for air, but good fuel came out the top bleede ...Missing: a4
Hi i am working on 03 gmc sierra it has a battery warning light on .when you put the key in the ignition and turn it to on the voltmeter does not move. if you go to start it . it turn over but does n
Check the voltage coming out of the alternator with engine running it should be 13-15 volts.If its not within these specs then replace the alternator.
I had to jump start my 2003 GMC Sierra 1500 and ever since the remote fob will not work, I can still lock using the manual door switch or key, the red light blinks and the on dash security icon...
try ignition with key in and turn to number 2 and press fob button if the doors lock its worked, it f not you need to remove the battery negative and turn ignition on and lights and leave on for a few moments then turn all off again, then fit battery and do the first part again. hope this helps you.
8helpful
I changed batteries in my 2003 GMC Sierra key fob
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
2004 gmc sierra acts like the key is in the ignition when its not, the warning bell goes off+the doors wont lock ,like the key is in the ignition
sounds like either key in cylinder contacts are bad or the 2 wires going up column to the switch are pinched together.
I'm getting 13.2 mpg on my 03 6.0 1500 hd. Is
Pretty much...had a 2006 Chev 2500HD Crew Cab 4X4 w/6.0; got 12mpg regularly...which is why it's someone else's truck now. Have a 03 1500 GMC 5.3 Ext Cab now; get 18-21 mpg. Sweet!
2answers
Have had 4 keys cut for my '02 gm x-cab & they fit the door, but don't turn in the ignition very easily. do I need factory gm keys (because of a chip or what?)
No, the chip will not cause you not to be able to turn the ignition. The new keys need to be worn down a little to work properly. Over time keys wear down and stop working right. New keys cut in a automatic key maker are normally too "high" for the tumblers in the lock making it hard to turn. You can add graphite to your ignition which should make it easier as your ignition becomes used to your new keys. You can find graphite at Autozone for about 4 or 5 dollars.
Is it hard to replace a broken door handle on the outside driver side door of a 2004 gmc sierra extra cab with power windows and door locks?
its tricky but not hard. remove the door panel and put the window up, look in with a light and it will be obvious what to do......
37helpful
4answers
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
